TRIAC - Protection Methods
Sbchand
Oct 22, 2018
HI,
I am working with a Triac to control a 230V 60W incadancent bulb. The problem is that when the bulb fuses it take away the Triac as well. after a bit of a research I found out that it was due to short circuit. I tried adding a fuse to no avail. Is there any other method? any help will be much appreciated.
SBC
14,317
When a bulb fuses it normally goes open circuit which can cause a large change in voltage across the triac in a very short time.
Look up triac snubber circuits. These are used to limit dv/dt across the triac.
Sbchand
Oct 22, 2018
Hi, Thanks for replying.
Yes they do go open circuit but the filament sometimes falls in such manner that they cause dead short circuit between L and N.
Thanks once again
