Trying to identify an SMD
dranobob
Feb 26, 2012
3
Quick history. My mother was trying to repair a lose panel on her dishwasher when she dropped it severing the ribbon cable. The panel is membrane style. So the plan was simply to build a new panel out of leds and momentary switches.
There are 5 SMDs that were in the membrane that I can't identify. They have a band on one side so my guess is a diode or capacitor. they all are the size and have a capital "A" in the middle. The A is clearly NOT the marking for the anode. This is the only marking besides the band. When testing with Diode setting on my meter, it only shows voltage for one direction and that reading is 0.535V. So I'm leaning towards it being a diode. I am little out of practice building circuits, so forgive me if I say something odd or wrong.
Anyone have any ideas on what this is? I am trying to figure it out so i can order the soldered kind to use in my new panel.
EDIT: Also I get ~1M Ohms one way and Open the next, so pretty convinced its a diode, just trying to figure out what its specs are?
14,487
hi there
welcome to the forums :)
some photo's of the unit would help us help you else we are just guessing
make sure they are well focussed so we can read part numbers etc
cheers
dranobob
Feb 26, 2012
3
Here's the picture, had to use a jewelers loop to get it. its about 1mm x 2mm.
Yep, looks like a diode to me.
I *may* be able to get a possible part number, but with just an "A" on it, there's likely to be many options...
dranobob
Feb 26, 2012
3
if it helps. i popped one off and clean it up. it has a lead sticking off each side at the bottom.
Rleo6965
Jan 22, 2012
585
Diode test reading was ok. Why do you have to remove it?
