TWI code example for two AVR
pidy
I need code examples using TWI between two AVR units (in a Master->Slav
configuration)
I have seen examples either with only a Master and an EEPROM or somethin
else slave, but no examples of a full-blown communication channel betwee
two AVRs.
I m using AT90CAN128 but i think also code for generic AVR device its ok.
Your help is much appreciated,
Daniele
SioL
pidy said:
I need code examples using TWI between two AVR units (in a Master->Slave
configuration)
I have seen examples either with only a Master and an EEPROM or something
else slave, but no examples of a full-blown communication channel between
two AVRs.
Daniele
Does it really have to be I2C?
SioL
MK
pidy said:
yes I have to use TWI, if its what u mean
There is a good example on the Silabs website for their 8051 based
processors which seem to use exactly the same TWI/I2C interface hardware as
Atmel. Since the example is in C you can port it pretty much directly with
some name changes.
I've done it the other way round when moving a project from a Silabs part to
an Atmel (my own code I hasten to add NOT the Silabs code).
Michael Kellett
www.mkesc.co.uk
Eeyore
some name changes.
Interesting. I must have missed out on this TWI thingy ! What is it ?
Graham
martin griffith
Graham
its the dreaded firrips I2C protocol.
OT just been looking at the Grace design 802 remote mic amp, they use
I2C over a 1000 foot run, seems dumb to me
martin
Spehro Pefhany
Graham
I'd guess "two wire interface" (prolly I2C by another name to get
around Philips licencing/licensing issues).
Best regards,
Spehro Pefhany
John Woodgate
That dates you! That 'firrips' ad was run in 1978, I think.
martin griffith
Advertising works, Havent bought anything with a philips label since
martin
pidy
processors which seem to use exactly the same TWI/I2C interface hardwar as
Atmel. Since the example is in C you can port it pretty much directl with
some name changes.
I've done it the other way round when moving a project from a Silabs par to
Michael Kellett
www.mkesc.co.uk
thank u Michael... but i couldnt find the example u was talking about..
couldnt find no example with TWI/I2C interface...can u give me link??
thanks a lot
Daniele
Eeyore
Oh ! No problem there then. I have my own I2C routines ( not for master slave
admittedly but I dare say that could be fixed ).
If it works ! One of the nice things about I2C is that you can run it at ony old
speed. Doesn't mind being interrupted either.
Graham
Eeyore
pidy said:
thank u Michael... but i couldnt find the example u was talking about...
What *exactly* is it you want ?
Graham
pidy
Graham
Hello Graham..
I should need the code for the master device and the code for the slav
device... but in my case the master and the slave are 2 AVR-AT90CAN128.
I have those 2 devices and want realize a comunications between them usin
TWI.
Thanks a lot
Daniele
Eeyore
pidy said:
Hello Graham..
I should need the code for the master device and the code for the slave
I have those 2 devices and want realize a comunications between them using
TWI.
Why does it need to be I2C then ?
Don't they have serial ports ?
Graham
MK
thanks a lot
Daniele
The Silabs website is www.silabs.com
You will need to register and then search the tech library for SMB (they
call I2C SMBus). You'll get a few hits but you need to look at the app note.
Michael Kellett
pidy
Graham
sure, they have serial ports but i need to use TWI
SioL
Will the master always be the master and the slave always the slave?
If so, code is available either from atmel website or a number of other
sites, just google. It may not be for exactly your model of AVR, but
adapting the code should be easy enough.
SioL
pidy
ok I'll post some code... look if it could be ok
Master.c
#include <avr/io.h>
#include <compat/twi.h>
#include <inttypes.h>
int TWI_Master_Transmitter(uint8_t data, uint8_t address);
void TWI_init(void);
void TWI_Master_Transmitter_Error(void);
int main(void)
DDRA=0xFF;
PORTA=0xFF;
TWI_init();
int a;
a=TWI_Master_Transmitter(0xAA,0xE0);
if(a!=0)
PORTA=a;
void TWI_init(void)
#define SCL_CLOCK 100000L
#define F_CPU 8000000UL
/* initialize TWI clock: 100 kHz clock, TWPS = 0 => prescaler = 1 */
TWSR = 0; /* no prescaler */
TWBR = ((F_CPU/SCL_CLOCK)-16)/2; /* must be > 10 for stable operation */
TWCR=(0<<TWINT|1<<TWEA|1<<TWEN);
int TWI_Master_Transmitter(uint8_t data,uint8_t address)
uint8_t twst;
PORTA=0xFF;
TWCR=((1<<TWINT)|(1<<TWSTA)|(1<<TWEN)); //Start condition
while(!(TWCR&(1<<TWINT))); // TWINT 1
twst=TWSR;
twst&=0xF8;
//Check TWSR START=0x08 REP_START=0x10
(twst!=TW_START)&&(twst!=TW_REP_START))
TWI_Master_Transmitter_Error();
return 1;
PORTA=0xFE;
TWDR=address; //Load SLA + Write (Write=0)
TWCR=((1<<TWINT)|(1<<TWEN)); //Send address
PORTA=0xFD;
while(!(TWCR&(1<<TWINT))); //TWINT1
PORTA=0xFC;
twst=TWSR;
twst&=0xF8; // Prescaler
if (twst != TW_MT_SLA_ACK) // check TWSR SLA_ACK=0x18
return 2;
TWDR=data; //data in TWDR
TWCR=((1<<TWINT)|(1<<TWEN)); //Send data
PORTA=0x8B;
PORTA=0xFA;
twst=TWSR;
twst&=0xF8; //Prescaler
if(twst!=TW_MT_DATA_ACK) //check TWSR MT_DATA:ACK 0x28
return 3;
PORTA=0xF9;
TWCR=((1<<TWINT)|(1<<TWEN)|(1<<TWSTO)); //Stop condition
PORTA=0xF8;
return 0;
TWCR=((1<<TWINT)|(1<<TWEN)|(1<<TWSTO)); //TWI - Stop
TWCR=(0<<TWEN); //TWI-Aus
PORTA=0xF7;
SLAVE.c
#include <stdlib.h>
#include <stdio.h>
#include <util/twi.h>
#include <avr/io.h>
unsigned char s_addr, rdata;
unsigned char tdata;
const char CDATA[]={0x01,0x80,0x02,0x40,0x04,0x20,0x08,0x10};
void port_init(void)
PORTB = 0x00;
DDRB = 0x00;
//PORTC = 0b1001111;
//DDRC = 0x00;
PORTD = 0xFF;
DDRD = 0xFF;
//TWI initialize
// bit rate:1
void twi_init(void)
TWCR= 0X00; //disable twi
TWBR= 0x01; //set bit rate
TWSR= 0x00; //set prescale
TWAR= 0xE0; //set slave address //0x01
TWCR= 0x04; //enable twi
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
//CLI(); //disable all interrupts
port_init();
twi_init();
void ERROR(unsigned char edata)
PORTD= ~edata;
while(1);
unsigned char SlaveReceive(void)
TWCR = (1 << TWINT) | (1 << TWEN);
// TWAMR = 0x00;
TWAR = ((s_addr <<1) | 0);
TWCR = (1 << TWEA) | (1 << TWEN);
while (!(TWCR & (1 << TWINT)));
if ((TWSR & 0xF8) != 0x60)
ERROR(3);
TWCR = (1 << TWINT) | (1 << TWEA) | (1 << TWEN);
if ((TWSR & 0xF8) != 0x080)
ERROR(4);
rdata = TWDR;
if ((TWSR & 0xF8) != 0x0A0)
ERROR(5);
return rdata;
void SlaveTransmit(void)
// TWAMR = 0xFE;
if ((TWSR & 0xF8) != 0xA8)
ERROR(0x30);
TWDR = tdata;
if ((TWSR & 0xF8) != 0x0C0)
ERROR(0x40);
void main(void)
init_devices();
s_addr = 0xE0; //0x50
PORTD =0xAA;
while(1)
rdata = SlaveReceive();
tdata = CDATA[rdata];
SlaveTransmit();
PORTD = ~rdata;
