Eeyore
- Jan 1, 1970
- 0
Then you don't need to consider master-slave operation.
Graham
pidy said:uhm... what u mean??
SioL said:It means you just need to configure one of the AVR as a slave and
the other as a master. Should be pretty easy.
I suggest you setup the master first and than test it with a known working
slave, perhaps eeprom.
Once that is working setup the other AVR as a slave
and work on it until the entire system is working.
It may be helpful to have storage scope or logic analyzer to check the bus,
if you get stuck.
C source for slave and master is available from atmel or avrfreaks, its the asm
code that's a bit harder to find from my experience (but it exists as well).
http://www.atmel.com/dyn/products/app_notes.asp?family_id=607
check avr310,avr311 and others
Eeyore said:I've never needed it. It's so easy to code it's hardly worth that kind of trouble.
I need code examples using TWI between two AVR units (in a Master->Slave
configuration)
I have seen examples either with only a Master and an EEPROM or something
else slave, but no examples of a full-blown communication channel between
two AVRs.
I m using AT90CAN128 but i think also code for generic AVR device its ok.
