I just want to check if I am understanding the SOA graphs correctly on a datasheet..
The STP30NF10 MOSFET is rated for 100V and 35A.
http://www.datasheetcatalog.org/datasheet/stmicroelectronics/7817.pdf
The SOA graph shows that the actual current it can pass varies with Vds. Now the graph goes upto 100V, but Vds (when on) should be really small, so is this referring to the Vds voltage when off?
Looking at the graph, and taking a 24V supply as an example, it looks like it could only switch something less than 5A. Is this correct? Is this still true even when on a large heat sink?
It also shows the current handling peaking at around 3.5V. I don't really understand why lower voltages lower the current ability. Its also seems odd that a transistor rated for 100V, 35A should only work at 35A when switching from a 3.5V supply.
Where am I going wrong?
