UPS - mains voltage / output voltage not synchronized
Pascalou
Jun 27, 2017
Hello everyone,
I hope I write in the right place of the site. My question is about an UPS (Uninterruptible Power Systems) Claude Lyons. An indicator has started to flash, it indicates that "the UPS is operating from the mains, but the output voltage is not synchronized with the main voltage".
I would like to know if someone knows this system? And is there a way to synnchronize these two voltages or if it doesn´t
matter to work in this condotion.
Thanks by advance.
Pascal.
14,479
not off hand .... do you have a model ?
And is there a way to synchronize these two voltages or if it doesn´t
matter to work in this condition.
I cant see why it would matter .... as far as I'm aware, synchronisation is only needed when bringing 2 AC voltages together
a particular example would be synch'ing generators in a power station
ramussons
Jun 10, 2014
475
Hello everyone,
Thanks by advance.
Pascal.
If yours is an "Online" UPS, its output voltage and frequency is not dependent on the Input. It will have it's own Frequency and Output Voltage, both which can be set.
But, as mentioned in the earlier post, the make and Model Number will be helpful in getting better information.
