UV LEDs die fast?
John Bokma
Out of a batch of 50 UV LEDs two have "died" somehow. With the first one I
thought it was a bad connection, so I re-soldered the LED, and it worked.
When I turned the circuit off for some time, same problem. So again I
thought: "cold" connection, re-heated it, and worked...
But when the circuit got cold again, same problem. I replaced the LED, and
no problems for hours.
Two days ago, however, another LED stopped working, same problem. Heating
it, it works again. This time I was able to "see" (indirectly, UV LEDs can
harm your eyes) what happened: the three LEDs in series started to flicker
for some time, and then all went off. Heating it -> works.
Does anyone have an idea why this is happening? Just 2 bad LEDs out of 50?
See http://johnbokma.com/pet/scorpion/detection-using-uv-leds.html for the
circuit diagram.
Also: I use most of the time 9V to feed this circuit, so I doubt it has
anything to do with overloading the LEDs.
TIA,
Lawrence Oravetz
John Bokma explained :
circuit diagram.
TIA,
look at the traces leading to the led. Is a pad lifted? or has a crack
in the board developed?. reheating is the key common factor.. I'd look
for external faults before the led.
John Bokma
2 more leds have died. I bought a digital meter, and am going to do some
measurement. I got more and more the impression that the shop sold me
garbage. (Especially since I use 9V to run the circuit, not 12).
Don Klipstein
Should you determine that it is the LEDs, could you tell us what brand
these LEDs are?
John Bokma
brand
these LEDs are?
I have no idea about the brand, but I ordered them from LSDiodes.com.
They seem to have a good reputation, but I am amazed that I manged to
kill 4 UV LEDs, especially since I thought they would last for thousands
of hours.
I'll check it out next week.
