Hi
I want to add a linear PS to a SMPS to improve regulation and vary the output voltage between 0-30V. The Vi in the schematic comes from SMPS .In worst condition it has 250mV ripple.
To reduce power dissipation in trasistor I plan to change Vi when I want to
change Vo, But I always have to keep (Vi), 3.5V higher than (Vo) to keep LM317 working proplerly.
{the trasistor turns on when LM317 darws 20mA. the input voltage of LM317 must be 2.5V higher than its output. If Veb=1V then (Vi-Vo = 2.5V + 1V =3.5V) }
when I draw 10A, My SMPS should produce 35W more (10A * 3.5V) and dissipate this power in Linear PS.
I want to know how can I do a trick which enables me to reduce this Differential Voltage(3.5V) Lower. i.e. down to 1V
which components can I use instead pf LM317.
