I'm looking for a voltage divider that also has its output clipped at about 3V.
I need to do voltage measurement and I'm going to use a voltage divider. I want to "magnify" the lower region.
The input is 0 to 20V but I'm really interested in 0 to 4.2V (Li-Ion battery).
So I thought I use a divider for the region of interest and clip the rest.
R1 is 6,000 Ohm, R2 is 10,000 Ohm.
The Zener I'm considering is DDZ3V0BSF-7 (Diodes Incorporated).
The Zener voltage is 3.01V to 3.22V, let's assume it is 3.1V.
Unfortunately I don't think this will work as it is.
At 4.2V at the input, the output is 2.6V. So far so good, but the current will be only 0.4mA. The Zener is already letting this amount of current pass through at 2.6V, and this will mess up the measurement.
I assume to fix the problem I will need more current coming through R1 and in addition re-scale the divider and say that anything above 2.5V will already have significant leakage through the Zener diode.
I also can't make R1 too small because at 20V I have to keep in mind how much power the Zener can clamp before burning up (500mW).
Any clever ideas or thoughts on how to do this very efficiently? The current consumption doesn't matter because it is only powered periodically.
As for my own idea, I'm considering two voltage dividers in series and the zener coming between them.
