Voltage Regulator for 30W solar
goodjboy
Apr 27, 2012
10
I want to build a voltage regulator that can handle 30 watts of power input and output with input voltage around 17 volts and an output voltage of 5 volts.
I have a 30watt solar panel and I want to power a bunch of 0.5 watt USB AA battery chargers with it.
I know about the 7805 voltage regulator from Radio Shack but I am not sure how efficient it is. It looks like that regulator can handle up to 5 watts. My thoughts were to build 6 7805 regulators and have the panel feed them all and then have all the regulators feed by chargers. Is this an efficient solution or will I lose a lot of energy to heat this way? Is there a better way to do this?
I would greatly appreciate any help my fellow geeks have to offer.
Thanks!
Using a 7805 to go from 17V to 5V is only 29% efficient.
A better solution would be a DC-DC converter. These are much more efficient. You can get them as modules or look for a switch mode regulator and build it yourself.
It looks reasonable. Any switch mode regulator should be far more efficient than 7805's.
goodjboy
Apr 27, 2012
10
Thanks!
Thanks so much for your advice. I just ordered 2 15Watt units for like $15. I am going to hook these two in parallel with the solar panel and hook in a bunch of the USB AA battery chargers to them. Thanks again...
