While voltage dividers may be used to produce precise reference voltages (that is, when no current is drawn from the reference node), they make poor voltage sources (that is, when current is drawn from the reference node). The reason for poor source behavior is that the current drawn by the load passes through resistor R1, but not through R2, causing the voltage drop across R1 to change with the load current, and thereby changing the output voltage.
