shaiqbashir
- Jun 4, 2005
- 251
- Joined
- Jun 4, 2005
- Messages
- 251
for full version plz visit this
Hi guys!
i want to build a simple PIC programmer that requires 13.5 V. This can be to about 14-16V. And it also needs regulated +5V at some of its pins.
The diagram above shown is the power supply setup used for this programmer. There are two power solutions available. Either we connect two 9V batteries, or we connect AC supply to it. You can see the AC jack in in the diagram. Then we have a bridge with us. I want to know that does this socket requires to connect 220V AC supply to it and then the bridge will rectify it OR we should use an adapter that should be able to convert 220V AC supply to somewhat 14V or 16V?
What should we do to power this circuit.
Actually i have never used bridge before. If i go to the market, what specifications should i tell to the shopkeeper to purchase a bridge for the above circuit. I mean is there any voltage current requirement.??
Secondly, please look at the batteries connections, do u think that these are correctly connected.
im saying this because i see + side connected to the ground in the above diagram.
Thanks in advance!
