WATER LEVEL MONITOR FOR PUMPS
Omni
Apr 25, 2007
94
Ante said:
Arcing is NOT caused by switching IN a load! Arcing is caused when opening the relay contacts (switching out a load)!
The inrush current on a heavily loaded motor can easily cause an arc flash when switched in, i have noted it many times.
Generally, under the above condition a CB will trip but during the latter time an arc is present.
Obviously, the majority of time an arc flash is noted when a load is switched out.
Additionally, the issue concerning an arc flash must be addressed and corrected since contact properties will degrade in a non-linear manner.
The specification pertaining to the relay along with the current demand (potential) present at the contacts is the major issue.
Take some time and read the NEC, you may learn something...  ;)
ante1
Jan 24, 2004
4,136
You are way of; start reading up on things before you open up! There is NO arcing when the contacts are closing unless a. the voltage is high enough to jump across the contact pair before they are shut or b. the relay is stupidly under-dimensioned for the purpose! What you might se at the closing moment could be a spark NEVER arcing!
And you know what you can do with the
keron
May 14, 2007
55
hello guys ,
                       you are deviating from the topic.i have used a MOV for the sparking issue.its nota problem at all.but what about my question on pulldown resistors  please explain .do i need to use them in every  input of logic gates.even in case of output of a logic gate used as input to another.please explain
ante1
Jan 24, 2004
4,136
This will probably be useful: http://www.personal.dundee.ac.uk/~gathomso/EG2103/pull-up.doc  ;)
keron
May 14, 2007
55
thanks ante.but that is the basic .my question still remains.between output of a gate to input of other  gate pull down/up resistor needed?or just a pull down resistor at the begining of circuit will do fine?
ante1
Jan 24, 2004
4,136
Between gates there should be no reason for resistors.
keron
May 14, 2007
55
i have made some modification in the circuit.i am using two Metal oxide varistors .one for protecting relay terminals from arcing and the second protects the entrie circuit.
                            i have also included green and red LED as in diagram.they are connected from pins shown through a 330ohm resistor.
                                   also grounded the 12 volt supply rail through 330uF(electrolytic) and 0.1uF as in this pic
http://www.zen22142.zen.co.uk/Circuits/Alarm/water_lev_alm.htm
                         now iam facing two critical problems.one the green LED  remain on most of the time on switching on the supply to circuit  regardless of water level.after that circuit is not working properly.you can say not pumping at all.it has become entirely non functional.but sometimes in between testing it works properly.should i use a transistor switch than directly connecting the out from 4001 AND 4011 to LED through a resistor?
                                         as i said before iam using a transistor  comon collector circuit with only 100k resistor across base to amplify signal from probes.what can be the problem,any idea?
                                             in the same  circuit please someone tell me(http://www.zen22142.zen.co.uk/Circuits/Alarm/water_lev_alm.htm)why there is a 1Mohm resistor with 1uF cap inbetween the logic gates ,also the 47k and 10nF cap.please ?
audioguru2
Apr 6, 2004
12,022
I answered your questions about the Classic Cmos Oscillators in your other post.
audioguru2
Apr 6, 2004
12,022
keron said:
but what about my other questions?please help
you made many modifications to the circuit. Post your new schematic and we will see what is wrong with it.
keron
May 14, 2007
55
the modification is i have used red and green LED S in my first diagram.i have not used them in the original circuit.it was only in the theory part i used the LED.WHEN I USED IN MY REAL CIRCUIT NOW .The  circuit  malfunctioned.please see the diagram.there is some serious problem with the current schematic.i havent used the LED in my original working circuit.when i used  there is severe problemsin the circuit.no idea what is the problem.
audioguru2
Apr 6, 2004
12,022
The circuit should work fine without the LEDs. The Cmos gates don't have enough output voltage when directly driving LEDs. So they don't have the proper logic voltage levels.
Fix it by using inverters, gates or transistors as LED drivers.
keron
May 14, 2007
55
ok if i use a 500k resistor through which i connect a NPN transistor as a switch to the output pin it should work fine rt?
                                i think the powersupply is also a problem.i get shock from the neutral wire in my home.can it be a reason for my logic gate malfunctioning.when i touched the tip of soldering iron when the circuit was working it made the relay to switch on.what to do to make a good powersupply?rt now iam using a 12 volt fullwave rectfier and 1000uf capacitor .out put regulated through 9 volt regulator ic.when i test it somewhere it work fine.any solution to make a proper ground..
keron
May 14, 2007
55
i found out the problem finally.it was not the circuit.it is perfect.the probe was defective.it was made of paper clips .it got corroded and made electrical contact through the mixture of rust and the glue i used to fix it.i changed into a brass electrode and a silicone adhesive.now i guess no problem.thank you all for scraching your brain with me for finding a solution.any one with a better idea for probes.????
                                    http://www.uoguelph.ca/~antoon/circ/sensor3.htm
how to modify this for my use...
Omni
Apr 25, 2007
94
"the probe was defective.it was made of paper clips..."
Hehe, if you are every stranded on a deserted island i am sure you will survive!"  ::)
Good job!  :)
keron
May 14, 2007
55
or any idea to make ac signal for sensing water level?and then make it work with logic gates.
