What a bonehead!!! (repairing P PC PS)
W
William R. Walsh
Hi!
My experience exactly. Back in the 'AT' era, I don't think I ever had a ps
failure. I've lost track of how many ATX supplies I've replaced.
I think this may be due to a couple of things that I've noticed over the
years...
First--people complained of fan noise, so manufacturers cut down the voltage
to where the fans were just turning enough to move some air. Naturally this
causes the supply to run hotter. I've seen a few (IBM PS/2 Models 90, 95,
Server 5x0, 7x0, other computers) where a nice thermal control circuit was
included to "throttle" the fan up or down as needed. But thermal controls
cost money and aren't commonly seen. From the PS failures that I see, most
all of them are heat induced--badly 'bulged' capacitors and that sort of
thing.
I have here an HP Vectra VL mini/mid tower PC that is loaded--all the slots
are filled, all the SIMM slots are filled and the CPU was upraded from 233
to 300 MHz--and the power supply fan never even picked up speed once,
despite the fact that the output air was much hotter. I 'fixed' it by wiring
the fan directly to a +12V line in the supply. It's much louder now, but at
least the air coming out is of a reasonable temperature.
Second--the supplies made today, especially in lower end budget box
computers, are just plain cheap. (HP Pavilion supplies seem to be
notoriously cheap and they lead the pack by a wide margin when I think about
what I have replaced...) In the days of older AT supplies, the computer they
came with usually cost a lot more and the overall quality of the components
was much higher. I have loads of older systems using AT-and-similar power
supplies, and only a few have died over the years as compared to modern ATX
supplies...
William
W
William R. Walsh
Hi!
A linear power supply in a PC or newer computer?
I've been working with all kinds of computers new and old and I have yet to
see a linear supply ever being used in one. Every last one has been a
switchmode supply...
William
Clint Sharp
jak
Back in the PC/XT/AT/PS/2 era I made a damn good living repairing failed
IBM and IBM clone power supplies. IBM PC (CEAG 63 Watt!) XT, AT and PS/2
PSUs definitely failed and were very repairable because IBM charged so
damn much for them, Compaq were the same. Even the majority of the clone
supplies were worth repairing. We used to turn round about 25 to 50
units per week per engineer (sometimes more if we got a 'run' of the
same units and could set up a 'production line') and received a bonus
based on the repair price of the items, I could triple my basic salary
some months. We were very rarely 'quiet' in our workshop.
I suspect that the scale of IBM's operation was the major factor in the
numbers of failed supplies I used to see rather than any particular
reliability problems (with one or two notable exceptions, the IBM PS/2
Model 80 Schrack unit being the one that springs to mind, famed for its
violent and spectacular failures).
I now replace failed ATX supplies if the fan is noisy and toss the old
unit unless it's something really special, I guess that's progress!
