What can I use instead of a 27R resistor?
JGUSA
Oct 19, 2024
3
I'm working on a Commodore VIC-20 diagnostic harness project that requires the use of two 27R resistors. I only have 22R and 47R resistors right now. Can I use either the 22R or 47R instead? I don't know much at all about resistors. Sorry
Thank you!
Joe
AnalogKid
Jun 10, 2015
3,058
And we know nothing about your circuit.
The 22 ohm will obviously be closer to the desired value, but the lower resistance might create an overcurrent situation. It *really* depends on the rest of the circuit. Please post the schematic.
ak
Delta Prime
Jul 29, 2020
2,996
Welcome to Maker Pro.
If you use two 47 Ohm put, them in parallel will give you 23.5 Ohms. With that said this is a diagnostic harness ;I would wait & purchase a 27 Ohm 1% resistor.
JGUSA
Oct 19, 2024
3
Here's the hand drawn diagram cassette section that was created by Ray Carlsen. It's a loopback connector for testing the cassette port on an older version of a Commodore VIC-20.
JGUSA
Oct 19, 2024
3
Thank you all for the replies. Given my novice (at best) status, I ordered some 27R resistors that will arrive in a few days.
Thank you!
Joe
100R 10 turn....or standard pcb mount pot......adjust where ever you like.
