What is the component
Audioguru
Sep 24, 2016
3,656
Inductance is measured in Henries. 120 ohms is the resistance of the fine wire that has many turns.
The reactance at one frequency is also measured in ohms but it is not stated.
14,309
Allow me to disagree: "inductors" referenced in Ohms are usually ferrites.
@electronicsLearner77 : As in your other thread: you need to know the frequency a which the impedance is specified. Look up the datasheet of the component (type of component should be in the BoM).
Martaine2005
May 12, 2015
5,315
With the symbol shown, ie: solid lines, indicates to me that It’s an iron core inductor. Broken lines/dashes, indicate a ferrite core. So unless these symbols are being used incorrectly, I’d adhere to the schematic with its symbols.
Martin
14,309
@Martaine2005 : I agree to your statement about the solid lines. However, to me it is more likely an incorrect use of the symbol. Otherwise an indiuctance should have been given, as mentioned by @Audioguru , not an impedance.
By the way: The correct way to label the component would have been for example 120 Ω @ 100 MHz. Giving 120 Ω only makes no sense.
Audioguru
Sep 24, 2016
3,656
An inductor is labeled in Henries, not it impedance at an unknown frequency.
Is the impedance (reactance) of a capacitor labeled? No, its capacitance is labeled then you use math to calculate its impedance at a certain frequency.
AnalogKid
Jun 10, 2015
3,055
Please help me
know where this symbol came from. Please post a larger section of the schematic.
Absent that, I vote with HK - a pcb-mount ferrite bead with an impedance of 120 ohms at some specified frequency (typically 100 MHz).
ak
14,484
All 3 inductors in that circuit are on power rails. They are noise suppressors. They should be marked in mH or uH not Ohms
they all perform noise suppression on those rails
there is obviously some bad circuit symbol use. All 3 are most likely to be on ferrite cores, single or multi hole ones
or possibly just straight wound onto a ferrite core
for the many shapes and sizes
Ferrite Choke - Bing images
14,309
The circuit is obviously from this application note PDF.
There is no further detailed description of the circuit, its operation nor is there a BoM which could be used to find out what is really meant.
Lacking more detailed information I support @AnalogKid 's assumption of a ferrite with the specified impedance @ 100 MHz.
