What kind of relay is this?
OK, so if I place a 10V zener in series with that diode, what would the maximum collector voltage on the transistor be, and what would be the range of voltages seen across the relay coil?
Davewalker5
Sep 20, 2014
125
Steve here is some schematic clips with relays RC networks and an relay driver
Relay Driver has a FET Q2 , a transistor driver Q3
Most driver circuits don't have the FET, they just go direct to the transistor driver
The transistor is to output more current to the relay coil to energize it faster?
The FET is used for what? and without using the FET it would be the same? so what's the difference
Davewalker5
Sep 20, 2014
125
Here the schematic clip of the Relay RC network with the Series Diode we are talking about
The Capacitor stores the relays voltage and the 100 resistor drains off the coils slowly sinking it back to the power supply
The Series Diode blocks the capacitor from draining the voltage and current into the coil?
Davewalker5
Sep 20, 2014
125
Here is another Relay RC network suppressor circuit
This RC doesn't have the Series diode, so what happens now?
