Gus
- Jan 1, 1970
- 0
1/4" look a little big.
Gus
Where's Bass's Q&A when you need it...
Gus
Gus
Robert L. Bass said:Hi Gus,
I usually drill a 1/4" hole for 22/4 alarm wire (aka "quad cable").
The FAQ website is on its own server. The server is going to be off line
for a few more days while I set up the new DSL connection. I took it down
due to the evacuation. There will be a new URL for the FAQ website. I'll
post it here and in the automation newsgroups when it's ready.
The online stores are running on our new server in California and were
unaffected by hurricane Charley.
Alarm and Home Automation System FAQ
http://www.bass-home.com/faq/masterfaq/faq.htm
If the cable will be run through multiple studs or joists I agree. Use a
slightly larger hole. However, if it's only going through a single
opening -- say from a PIR down to the basement -- I've found a 1/4" hole is
fine. When drilling doors I prefer a 1/4" wire hole (slightly recessed into
the 3/8" hole for the switch). I find it's easier pushing the quad cable
through if the hole isn't too large.
