What would be the effect If I change 4700uF capacitor to 18000uF?
Prohor
Sep 27, 2016
34
I have a dc bridge rectifier circuit to make ac to dc 50 volts output. It required two 4700uF capacitor, but I have 18000uF 70v in hand. If I use this 18000uF capacitor instead of 4700uF, will it damage my amplifier circuit- stk4231?
Local electronic seller told that it will not effect if value is more than required, I have doubt ! please help.
Colin Mitchell
Aug 31, 2014
1,416
The only thing that might happen is the fuse will blow.
This is because the 18,000u will take longer to charge when the amplifier is turned ON and the fuse will pass a high current for a longer period of time and this will be seen as a short-circuit and it will gradually weaken and eventually die.
Need a circuit diagram. If this is a bipolar supply, which they usually are for high power amps, then the two capacitors are connected to ground in the middle, and you cannot replace them with one capacitor, if that is what you thinking of doing.
The change week have some effects.
1) the ripple on the output will be less at a given current with the larger capacitor. This may reduce hum.
2) the current surge at power on may be higher or longer. In the worst case this might blow a fuse but generally is not an issue
3) the peak current through the rectifiers week likely increase. This may stress them more, but the duration will be less so the difference may not be significant.
Making a
AnalogKid
Jun 10, 2015
3,058
I don't see the word "charge" in the thread title, post #1, or your quote. ?
ak
14,487
good point ,,, I didn't consider the possibility of a dual rail PSU
@Prohor ... as you were asked show us a schematic of your supply
Prohor
Sep 27, 2016
34
Thanks a lot. I was thinking something like this. As it is too much 18000uF, it should effect. I have tried with this and found 2 skt4231 IC damaged. I think it was charged too high and after switching off, it was releasing charge to be discharged too long. I have not found a power supply circuit diagram for stk4231 on google search. STK 4231 ic datasheet also not containing details about power supply.
Prohor
Sep 27, 2016
34
Thanks for your reply, I have not found a power supply circuit diagram for stk4231 on google search. STK 4231 ic datasheet also not containing details about power supply. I have just tried a circuit like
Re: I am having problem with image upload in this thread, is showing a "X" icon.
url to image is: https://s15.postimg.org/66ipv52bv/20161205_134828.jpg
and used four 1000v822j capacitor beside diode. Electronics seller told me that using 1000v822j capacitor will reduce noise during power switch on / off.
I did not find answer from him about 'AN70MM' shown in the pcb.
Prohor
Sep 27, 2016
34
Cirkit
Oct 28, 2015
156
That power supply has split rails - positive and negative. You will need two capacitors as mentioned above in another post. If the exact value and voltage specification isn't available. you can go slightly higher.
14,487
thanks for that upload :)
yes indeed it's a split rail supply so 2 caps as shown are needed
You CANNOT use a single cap in that application
