What's that black dust in monitors?
DarkMatter
Dont believe it. Its too fine for that and the distribution
inside the outer case doesnt fit that either.
Actually, it is dust from your local region that collects any
moisture in the air after it has been attracted to, and attached to
whatever surfaces of whatever charged devices are in the monitor case.
That would be the HV supply elements, and the tube itself. Then, all
the chassis collects, because it is the return for some of the fields
present. It takes on moisture and gains color. It isn't "baked".
This is why all military CRTs had fully potted HV supplies, and an
oversized anode lead such that less corona is generated, and dust
isn't as big a factor. Next to none on a supply that has a full
faraday cage around it.
DarkMatter
** All the facts fit.
Electrostatically charged soot consists of very fine particles,
follows air currents and sticks to plastic and metal.
It should actually read "sticks to charged surfaces". They are
usually non-conductors, such as plastic, but conductors that are
isolated from ground can gain charge, and become attractors.
Of course, electrostatically charged elements in a CRT monitor are
the huge capacitive picture tube. Quite a field surrounds them.
Phil Allison
** I was alluding to the chemical reactivness of soot particles - eg
soot from a fire in a fibreglass PCB leaves dark stains on plated metal
surfaces that cannot be removed with solvents.
............ Phil
Phil Allison
** That may be so unless the air is full of photocopier toner particles -
as when a busy office copier is sited next to the PCs. In the case I saw
all the insides of the monitors and the PC's PSUs with coated in the black
stuff.
............ Phil
DarkMatter
stuff.
Yes, and just like clean dry dust, it is a non conductive,
dielectric even material that will be attracted to any surface that
does not have a net zero charge.
Rod Speed
The real Andy said:
Thats my opinoin too.
Yup.
Seen it in heaps of electronic products.
You dont get the same effect with quite a bit
of that black soot on the inside of the monitor
case with other electronic products except TVs.
Rod Speed
All the facts fit.
Nope, dont fit at all. Particularly the distribution
of that black soot on the inside of the monitor case.
It isnt even where the bulk of the airflow happens,
so it cant be where the cooked skin ends up.
Yes, but it clearly cant be COOKED SKIN, and
isnt where the airflow happens in a monitor either.
Its always quite close to the FBT,
and so its coming from the FBT plastic.
AND its much worse in a monitor with a failing FBT which
you know is failing because you can hear it clicking and
you're getting the screen image changing when it does.
Rod Speed
It's not caused by arcing or my Tesla coil would be covered in soot.
Correct, and you dont get that soot with those.
Its gotta be coming from the FBT, because
its always on the case adjacent to that.
Cant be cooked skin either, but that area where
the you get the soot in a monitor isnt usually
where there is all that much airflow thru the case.
The source has to be the epoxy on the FBT.
Shit you're ugly, specially those red eyes |-)
Rod Speed
Actually, it is dust from your local region that collects any moisture
in the air after it has been attracted to, and attached to whatever
Doesnt explain why its black soot.
You certainly get the effect you are talking about on the front
face glass of the monitor and TVs, but its just dust colored.
You also get that effect with those ESD devices that claim to
collect the fine dust out of the air so you dont breath it etc too.
all the chassis collects, because it is the return for some of the fields
That black soot you get inside a monitor case close to
the FBT certainly isnt just dust, its black/very dark grey.
Nothing like the brownish/reddish dust we get so much of around here.
and an oversized anode lead such that less corona is
generated, and dust isn't as big a factor. Next to none
on a supply that has a full faraday cage around it.
It isnt dust. Its much too black for that.
Rod Speed
particles - as when a busy office copier is sited next to the PCs.
Sure but this is a red herring. Most home PCs dont
have any photocopiers around at all, and you still get
that black soot in all the monitors used in the home.
And its not cigarette smoke either. Thats got a
characteristic stink to it so you can tell which PCs
are used by smokers as soon as you open them.
Presumably its the tars you are smelling.
In the case I saw all the insides of the monitors
and the PC's PSUs with coated in the black stuff.
Yes, but you still get that with monitors that have
never ever been used anywhere near any photocopier.
V
Vermin
-snip-
That's not me dumbass.
Fucking stupid niggers keep askin for me bank account.
V
Vermin
Nope, you still get the black soot inside monitors in
homes like mine that are entirely electrically heated.
Nope, dont use a vaccum cleaner at all, ever.
Is that why the kipbble is 3' deep at your place rod?
Rod Speed
Vacuum cleaner aint the only way to clean the floor, stupid.
Specially if you dont bother with carpet.
H
Harry Conover
Jackie said:
What is that fine black 'dust' one sees inside monitors when the case is
removed?
Just curious
Jackie
Jackie, it's simply micron sized particles of various airborne
contaminants that are captured or precipitated out by the strong
electrostatic fields that exist within the monitor's case.
It's a pretty basic concept, so I'm a bit surprised that no one has
posted this explanation earlier.
If you watch the TV ads for Sharper Image's air purifier, which is
simply an overpriced electrostatic precipitator, you see them wiping
the same black stuff off of the outside of the collector plate.
(Strangely they never show you how to clean the same crap off from the
inside of the collector assembly!) :)
You will find the same stuff accumulating in any equipment where
strong electrostatic fields exist.
Harry C.
