Whirlpool Dehumidifier Vibration Noise Ordeal
Less than two years ago, I bought a Whirlpool dehumidifier model
AD50DSS2. This is a 50 pint, manual control unit. I wanted a manual
control type because I built my own controller which wouldn't work with
electronic control dehumidifiers. Note: It is hard to find a manual control
type of dehumidifier, which was common years ago.
I became very disappointed with it because of the vibration noise. The
noise isn't there all the time. I called Whirlpool about the vibration
noise, and they sent a service man. He opened up the unit and checked for
loose components. He put some kind of compound down where the compressor
is located. It seemed to fix the problem at first, but after he left, the
noise was back. I will spare you the details regarding the number of times I
worked on this "infernal machine". Note: I am a consumer products
service technician (repair TVs, etc.). It seems as though the "housing"
(cabinet) resonates with the compressor vibration, thus "amplifying" the
vibration noise. If I squeeze on the sides of the cabinet, the noise goes
down. The degree of vibration noise seems to be dependent on the room
temperature and humidity.
I can't tell you how many times I felt like getting the sledge hammer
and using it to fix the noise permanently, but where would I find a
manual control, 50 pint dehumidifier?
Before this Whirlpool, I had a quiet Goldstar dehumidifier (manual
control) for many years. Eventually the compressor went bad. I was told it
would be too expensive to get it repaired. Unfortunately, I put it out for
trash, and I bought this Whirlpool.
The reason I posted this is to warn you if you are thinking about buying
a dehumidifier, go with another brand.
John
PS, Email address is not valid.
PeterD
John
Look at some of the sound deadening products for the aftermarket
automotive field. They may do exactly what you want to get the various
vibrations damped...
Dori
Jerry said:
We found an electric kettle that was made in the US at a professional
kitchen supply distributor. This is a very rare species of appliance!
It was fairly expensive. I think it was nearly $200 for it. We have it
for over 3 years now, and it has not given any problem at all.
Big deal. The US is 1 step behind China in the manufacture of unsafe,
low quality goods.
