white led
audioguru2
Apr 6, 2004
12,026
You shouldn't operate the LEDs at more than their max current of 30mA each. 500mA/20= 25mA.
I don't know how high your mains voltage surges. I don't know why because mine never does. So I don't know what will prevent it.
jgeidl
Feb 24, 2006
35
I have been following this thread to see the outcome.  One thing, based on th elast drawing, that should be noted is that you are not working with 20 LED/resistor combinations in series, you are working with 20 LED/resistor combinations in parallel so you might want to rework the numbers a little.
I am also really happy to see the transformer get into play.  Runnig this circuit without a transformer is just asking for someone to get hurt real bad, as AG has pointed out earlier and repeatedly.
As to cost, I can't help but wonder if a 12VDC wall-wort transformer and, maybe,  a 7805 wouldn't be a quick, easy and cheaper solution to building the power supply cicuit.  Even better would be 6VDC wall-wort.
Just some thoughts...
Jim
audioguru2
Apr 6, 2004
12,026
Hi Jgeidl,
In his country a wall-wart is too expensive, the mains has high voltage surges and the LEDs don't have a forward voltage rating. It will be a miracle if he can make something that works.
pier1
Aug 21, 2006
180
Hi AG
        The project is fine now, working and having enough brightness, but for the resistor i put 10k 20watt , it is running cooler now . Thanks for the help . I am making the housing for it now .
Pier .
pier1
Aug 21, 2006
180
hi AG
The brightness varies about twice or thrice in some time .
pier1
Aug 21, 2006
180
Hi AG
        Hows this arrangement for the led's to switch when the voltage rise above 250 volts AC . Please tell me if this needs correction ?
Pier
pier1
Aug 21, 2006
180
i'm sorry i made a mistake , it is for the led's to switch off when the voltage rises above 250 volts ac .
Pier
audioguru2
Apr 6, 2004
12,026
Hi Pier,
An ordinary Triac or SCR is not turned off with its gate. The gate is used to turn it on and disconnecting its power source (like with each cycle of AC) or disconnecting its load current turns it off. Use a high voltage transistor instead.
I think high voltage zener diodes are very temperature sensitive and will begin conducting at a much lower voltage.
pier1
Aug 21, 2006
180
Hi AG ,
          Thanks a lot for the suggestion , could You sugest me which transistor would be good to use .
Pier .
audioguru2
Apr 6, 2004
12,026
I don't know which high voltage transistors are available in your country.
pier1
Aug 21, 2006
180
st13005 (to220) is available in my country . how about this ?
audioguru2
Apr 6, 2004
12,026
The high voltage power transistor is fine. With an LED current of 25mA then the base current is about 1ma. You will need a high voltage resistor or some ordinary ones in series to turn on the transistor.
High voltage zener diodes have a problem with temperature and leakage current. Use resistors to make a voltage divider then a comparator to activate which turns off the high voltage darlington.
pier1
Aug 21, 2006
180
hi AG
        Sorry I was a bit late . Could you send me a small schematic for the comparator . I tried and am not able to design it . Please help me .
Pier Francis
audioguru2
Apr 6, 2004
12,026
Making a comparator detect that the mains voltage is too high is simple, but giving it a reference voltage is difficult.
An LM10 is a voltage reference with an opamp and can be used. Can you get one?
pier1
Aug 21, 2006
180
You asked me " can u get one "
U asked me wheather can i get LM10 at my place ?
Or can i get the circuit ?
If it is the circuit u should help me ? I cant design perfectly.
I request u to please send me a schematic of the sensing .
audioguru2
Apr 6, 2004
12,026
An LM10 has a voltage reference and an opamp in a 8-pins IC.
The opamp is set to turn off when its inverting input is higher than the reference voltage, then it turns off the transistor.
Resistors are in series to double their voltage rating.
A voltage divider is used to reduce the DC sense voltage to be the same as the reference voltage.
More series resistors and a zener diode power the LM10.
I didn't calculate the resistor values yet because I wanted you to see how complicated this circuit will be.
pier1
Aug 21, 2006
180
Hi AG
        The circuit looks complicated but it is of interest to me . I dint understand what is that reference (200mV) you mentioned .
