Why do some devices turn on with the mains before the "On" button is pressed?
Status
Not open for further replies.
sacentre
Sep 27, 2014
29
I've noticed this behaviour with a number of cheap Asian consumer products I own eg Draco HDT-2 7700 DTB-T set top box, HAYEAR digital microscope camera etc. The Draco runs directly off 220VAC, the Hayear takes a DV12v supply. Both devices have power buttons on their front panels but they power up as soon as they're turned on at the mains, bypassing the panel button. The button will turn the device off. Why is this so common? Is is just a bit of corner cutting on the power supply circuit design?
Martaine2005
May 12, 2015
5,308
May be because most items having a standby circuit need constant power. So when plugged in, there is always power to the unit even when switched off. Hence the standby circuit waiting for a command. When I plug my TV in, it comes on and then goes off waiting for a command from the remote.
Martin
sacentre
Sep 27, 2014
29
Martin
As far as my experience goes "standby" mode is pretty much universal. Every TV, PC Monitor, VHS/DVD recorder, tape deck, audio amplifier, PC sound system etc I have ever owned works the same way: you plug them into the mains, a standby light comes on then the device waits for you to press the power button on the device itself or on the remote control to wake them up so you can start using them.
The devices I'm talking about don't do that. They wake up to full on without waiting for the button to be pressed. They can be turned off and on again with the button on the device or remote subesequently however, but if I kill the mains by unplugging or switching off at the socket switch, they wake up immediately once mains power is restored.
My guess is they were designed that way ie the power button is only used to turn the device OFF after initial mains plug in. Thereafter, the button works as BOTH on and off. I was just curious what the rational for it could be (if not cost cutting).
sacentre
Sep 27, 2014
29
Many domestic appliances these days never switch off fully: they only go into a deep sleep from which they can be woken with a button press or screen touch.
Except that the devices I'm talking about don't wait to be woken up with the button.
crutschow
May 7, 2021
991
That fault is especially annoying if the main's power goes out, since you then have to remember to go around and turn them all off after the power returns.
Martaine2005
May 12, 2015
5,308
Especially if you’re away on holiday!
But any smart person would unplug those types.
Martin
Martaine2005
May 12, 2015
5,308
But that is only practical for things you don't use often.
Perhaps easier to plug into a power strip with a switch.
Yes totally.
I used ‘unplug’ to mean turn off, disconnect, switch off etc in whatever manner. Because each unit might be in a different room.
Martin
So don't buy them....you seem to be aware of it and yet persist in buying them, then complain of the outcome.
Who knows how the designers of these things think....
good bet it's to do with being cheap though.....:rolleyes:
John Canon
Jun 1, 2022
91
The sudden application of power will cause a small surge to the various capacitors in the device. The inrush will then cause solid state devices to receive false triggers unless there is good circuit design to prevent these false triggers
The 2 cheap Asian consumer products you own obviously do not have that good circuit design. Your complaint is noted.
sacentre
Sep 27, 2014
29
Thank you John. That was helpful. I was wondering if adding a suitable cap somewhere might fix it.
I guess my use of the word "cheap" turned out to be a little problematic but was in no way meant to sound as if I was complaining about the devices (which seems to have ruffled Bluejets' feathers). This was completely unintentional. Maybe I should have said something like "low-cost and otherwise perfectly satisfactory for the price". In point of fact, the DVB-T box was distributed FOC here (Singapore) by the govt to help the transition from analogue TV but I would happily have bought one anyway with or without the power issue.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,985
Anything that responds to a momentary button press needs power to recognize that event. That is the rational for it.
My SONY flat-screen TV has NO front-panel controls, and it sometimes behaves in strange ways, because it is an Android device that Sony apparently cannot program properly. Sometimes, when it is behaving particularly snarky, I have to unplug the TV, wait for the internal power supply to discharge, then plug the TV back in again. Then I have to use the remote control to turn it on again. Unlike your "problem" my TV starts up in "off" mode. If I want to watch a TV program I have to press the "power on" button on the remote. This button, if held down, will also "reboot" the TV software, but I have found it much easier (and quicker) to just unplug the TV to force a reboot. But, in particular, the Sony handles Bluetooth poorly.
I have a Logitech Bluetooth headset, with an attached boom-microphone, that I use for Zoom meetings with this laptop. I also use it for listening to the Sony, with just the earphones, so as not to disturb anyone else. My laptop has no trouble pairing with the headset, but I generally have to disable Bluetooth on the TV for the headset to work with other Bluetooth devices anywhere else in the house. I leave Bluetooth enabled on the laptop, and on my cell phone, all the time without problems. My implanted pacemaker/defibrillator uses the cell phone Bluetooth to transfer data from the implanted device, and to "phone home" and transfer that data to the clinic that monitors my implant. So, its cell-phone app needs to run all the time. Technology is out of control IMHO. Just ask my wife for confirmation.
Status
