Why does a transistor heat when base current is high
audioguru2
Apr 6, 2004
12,022
Which transistor?
Why is the base current high?
What amount is the base current?
What amount is the collector current?
Why doesn't the transistor have an adequate heatsink?
princestephenranji
Jun 1, 2006
11
i tried many transistors like sl 100,bc 548 etc in these the base is connected to voltage source through a high value resistor (some 1 kilo ohm) when i tried to decrease the value of resistor,output current to load decreased and transistor temperature increased.why transistor temperature increased & output current decreased when i decreased the value of resistor.
allvol
Nov 30, 2005
101
Hello, prince
How are you using your transistor?
indulis
Nov 21, 2005
488
Two reasons come to mind right away.........
1) base current isn't being limited
2) you have a high emitter current with a high Vce
princestephenranji
Jun 1, 2006
11
Hi alivol,
              I tried to use transistor as a switch,also i dont know how to make a schematic picture.i just experimented with transistor,resistor and a relay.
Hi indulis,
              You are currect,emitter current is high which is essential to switch on the relay,i want to know the theory behind this heating
              Thanks to everyone who replied & read my post.
audioguru2
Apr 6, 2004
12,022
The relay coil is an inductor. An inductor creates a very high voltage when its current is stopped, the voltage can destroy its driving transistor unless a diode is connected across the relay's coil in reverse to arrest the voltage spike.
Heating is caused by the voltage across the transistor multiplied by the current through it. Relays are available that use a fairly low coil voltage and current. Then when the driving transistor is turned on, its base current is very low, its load current is low and the voltage across it is very low so it doesn't heat.
