Richard Fry
- Jan 1, 1970
- 0
________It has nothing to do with sync pulses. The sync occurs during the
blanking time at the beginning of each picture frame.
Note that sync pulses are transmitted between each horizontal LINE
(not frame), and in the vertical interval between interlaced fields.
The peak amplitude of the sync and equalizing pulses is transmitted
with the maximum ERP allowed for the TV station, which makes for more
stable pictures on receivers in weak signal areas.
The power ratio of peak-of-sync to reference black video in normal r-f
transmission is about 1.68 (NTSC). In fact, the peak output power of
an NTSC TV transmitter is determined by measuring the average power
dissipated in a matched dummy load when the transmitter is modulated
by reference black + sync, and multiplying that value by 1.68.
If the peak of sync was transmitted at 100% NEGATIVE amplitude
modulation, as it would be without inverting the polarity of the
composite video waveform from the studio, then the ERP of the TV
station would be zero at the peaks of those pulses, with which TV
receivers could have a problem.
