walid
Members
  • Posts
    749
  • Joined
  • Last visited
Everything posted by walid
  1. Hi all my friends When somebody build a batt charger that stop charging when batt full, he must use a comparator to compare batt voltage to some referance voltage.. when i conect a 3 volt batt to 5v power supply and wat to measure the woltage across the connection, what would it be? i ask this question to know at what level of charge i must stop the process if i have four 1.2v batts (total = 4.8v), now these batts are not fully charged, its voltage = 4 v or less. i want to recharge them using 6v power supply. if i connect a voltmeter across the connection, what would itsreading at thenbegining and at full charge i hope that u uderstand me yours walid
  2. Hi all you are not respond to my last question, so i'll do more efforts to simplify the picture to myself, but still need your help. The table shown below is a cut and eddit from the datasheets of MC14093B. From this table I understand the following: When Vcc = 5 vdc, this gate considers (typically) any input voltahe down to 2.9 vdc as logic 1, and any input voltahe up to 1.9 vdc as logic 0 Questions: (1) Is the above true? (2) There are three values related to the threshold voltage, min typ and max, which one to rely on? (3) the table show three values for Vcc; 5 10 and 15 vdc, what can i do if my vcc = 7 volts dc? (4) In the same datasheets, not shown in the table below, i found what is called Hysteresis voltage, its value is 1.1v at vcc =5v, 1.7 at vcc = 10v and 2.1 at vcc=15v. what this means and how can be used? the 2nd step is to use the above info with some exponentioal expressions related to capacitor to discover how exactly the charging process and the rate at which voltage developed between its plates. then I'll see how the R2 (as apart of voltage divider) isfunctioning in the whole circuit. I'll get the datasheets of 74HC132 and study it carefully and do all the calculations needed to understand how this circuit works.
  3. I agree with you that R8 reduce the max resistance between the probes, but R2 is not. R2 do another job, I think its function is as follows: Assume R8//soil resistance is very low, say 100 ohm (moisture content is very high) Our main ocs. changes its state every 250 micro sec (f=2KHz) If logic 1 is at pin 6 then logic 0 will appear at pin3, this will last for 250 micro sec Now at this situation, current will flow from pin6 through R8 to: 1) Charge C3 2) Pass through R2 to the virtual ground pin 3 If we omit R2, then C3 will be fully charged in 1.1*100ohm*1n = 0.1 micro sec let it 1 micro sec, this is very small time compared to the 250 micro. This means that pin 13 of the NAND gate will be low only for 1 micro sec from the 250 micro sec. BUT if we let part of pin 6 current to flow through another pass, then we slow the rate of charging C3 and gain more time I know that the designer said, the led must be dark when the moisture content is high, but what i said will be more clear when the moisture content become low and R8 high. I can conclude that if we carefully choose R8 and C3 we can then omit R2. What audioguru say?
  4. can you please put your circuit for others to look and think abput it.
  5. Hi audioguru, thank you for everything (1) If we ignore, for a moment, the formula you gave me later to calculate freq, and concentrate on the statement you told me:((A Cmos Schmitt trigger switches when its input voltage is fairly close to zero volts while an ordinary Cmos oscillator switches when its input voltage is close to half of the supply voltage.)) Looking at the word "half", I notice that this is the key to solve one problem. all the time I calculate the freq and get answer = half yours, so I can conclude that: The freq of an ordinary Cmos oscillator 1/(1.1RC) while for A Cmos Schmitt trigger oscillator, f = 2/(1.1RC), that is the time is half and the freq is double. Is this approximation is accepted by you? (2) If C3 charges and discharges through R8 (and the equivalent resistance of the soil in parallel), why we need R2 (=100K)? i think it has no function!
  6. use google get datasheets and read it
  7. Hi all Now I can move to another part of this complex (at least for me) circuit: In Fig. plants2 shown below I cut this part of the circuit because I think that this is a stand-alone osc. In his description, Audioguru did not tell us that gate IC1-B is a stand-alone osc, he said that this is a NAND gate. I'm not sure that this osc. does not affected by neighbor parts connected to it (as shown in Fig. Plants3), but at this moment lets start with Fig.plants2. Tc = Td = 1.1 R1 C1 = 1.1 * 470K * 1n = 0.517 msec So, time period = 1.034 msec ~ = 1msec frequency = 1KHz (if we take guru's last fotmula we get another value) Now if you look at Fig.plants3, you may notice that I omit the two probes and write on R8 that its value change from few ohms to 47K according to the state of the moisture content. From this figure we see that the designer connect his osc. (IC1-B) to NOT gate (IC1-A) and this combination works like this: When there is a 0 at the o/p of the osc. (pin 6), then 1 appears at pin 3, so cap C3 charge through R2 only and the R8 resistor connected in parallel with the C3.
  8. Hi all my friends, i miss you all, it is good to back In the Fig.plants1 shown below there is a part of the circuit, this part is the IC1-C work as 2 Hz osc. As the author said. Pin 10 is connected to 3v Vcc R3 = 3.9M R4 = 100K C4 = 220n D1 = any small signal diode The designer wants that the cap C4 charged through R3 and discharged through (R3//R4 = approx R4). As I understood (may be wrong) the purpose of using this osc. is only to save batt (for more info look at: http://www.electronics-lab.com/projects/science/018/index.html) If you don't worry about power supply you can omitt this part because it has no real function in the main circuit. To calculate the charge time Tc = 1.1 R3 C4 = 943.8 msec The discharge time Td = 1.1 R4 C4 = 24.2 msec The total period = approx. 1 sec So, frequency = 1Hz I know the picture is not so simply, Audioguru did not calculate it like this, his frequency = 2 Hz and he said that: "IC1C is another CMOS Schmitt trigger oscillator at about 2Hz. D1 and R4 discharge C4 quickly so that its output is low for only about 15ms with a 3V battery, and about 25ms with a 2V battery." From this we conclude that we must take the supply voltage into account; that is the higher this voltage the faster the charging and discharging process. This looks like filling the same tank, first using 2 hp pump then by using 3 hp. But the question still in my mind is how to calculate these times taking voltage value into account. After receiving a satisfactory answer I'll discuss more parts of this professional circuit. Yours, Walid.
  9. Hi audioguru yes this is true, i hope that you always teach me.
  10. this is excellent answer thank you audioguru
  11. Hi audioguru First thank you very much for your time with us I disagree, long time ago we have taught that caps are approx. short circuit during the charging or discharging process, so it connects pin 6 to ground... What u mean by snap action and hystreisis, i know that snap is a very quick and high voltage pulse. ===================================== Now I have more questions like: (1) Why the designer did not use another diode in series with R4 to make the discharge process only through R5, since R4//R5 approx = R5 (2) From your point of view, what the modifications that must be done to the circuit to work more efficient with less components? thank you
  12. hi audioguru I think that u mean pin 5 not pin 3 You may mean the internal (inside the IC) transistor. This is OK, i calculate and understand it but i have question: now let the o/p at pin 7 is 6volt then the voltage at pin 5 = 4v, if pin 6 is at ground, the o/p at pin 7 will remain at 6v. to change this o/p, pin 5 voltage must be less than pin 6 (5 more -Ve or 6 more +ve). can u, please, tell me more about this mechanesim of oscillation. thank you.
  13. this is a good and simple answer, i understand it , thank u audioguru
  14. Hi guru you deal with us as we a big experts, u must simplify your answers i'm hardly understand u. u must take a low level persons (like me) into your account. thank you
  15. Hi guru, thank u very much no it is 6 volt (4 x 1.5V batt), the +ve terminal is 6V and the -ve terminal is 0 V. From where u get the + and - 9 volt u want to say that a "pull-up" resistor connect the point to +batt and the a pull-down resistor connect a point to ground
  16. Hi audioguru, thank u very much for your kind answer. (1) pin 5 always connected to the voltage divider formed by R1 and R2 and so it is always at 3v potential, correct me. (2) How u reach these numbers, +-2.7v (3) What the values of the o/p at pin 7? It is the first time for me to hear about negative charging! What is a pull-up resistor and what it do? Than u very much
  17. I understand the 555 timer IC when used in its astable mode as an oscillator, but the one shown below i need some help in: (1) how this oscillator work? (2) the function of the diode? (3) how to choose the components values to achieve some freq.? (4) What the formula used to calculate the freq.? (5) Can I replace Q1 with a NPN one? Note that bat = 6 v and IC = LM393 Thanks to everybody
  18. hi your question is very important for me also, and i wait the answer, but please send the full datasheet to ren_ADD to enable him to answer. thanks
  19. Why you enlarge the problem, try to forget the datalogger for a monent, my question is very simple i ask if you work in TV corporation and you notice that there is some bars in the picture and a hum in the audio and u want to prove to the others that there is a ground loop what you tell them and what measurement you must make to support yourself. thanks
  20. Hi indulis, I'll concentrate on this air gap, what the distance? and how the energy stored in this gap? thank you
  21. What i mean is that the ferrite core transformers like a flyback or the one used in a switched mode power supply has an air gap to stor energy.
  22. what about air gap in which they store energy
  23. Hi I read this somewhere: "a regular transformer is designed to transfer energy from its primary to secondary and to minimize stored energy." Can someone please explain how they minimize the stored energy, that is what they do to minimize it? thanx
  24. walid
    filter
    I want to learn
  25. hi all u all must know that i am the only person among tens in my work who has the chance of conncting with u and the natural result of this must make me the more understanding person and this is not occur till now ok i am in advance but slowly..... now i have a FLUKE 112 TRUE RMS MULTIMETER and a video monitor and a video casitte, there is a hum in the picture, how to do some measurements to fix it? Greetings... Merry Christmas.... to all walid
