please help me find the right software for this program... i make a project about speech recognition.. i use HM2007 chip for this project.. my project is to convert a voice to text... if anyone know about this project, please help me guys... :( URGENT!!! Thank You.. PROGRAM: define osc 20
DEFINE LCD_DREG PORTD 'LCD data port
DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
DEFINE LCD_RSREG PORTC 'LCD register select port
DEFINE LCD_RSBIT 7 'LCD register select bit
DEFINE LCD_EREG PORTC 'LCD enable port
DEFINE LCD_EBIT 5 'LCD enable bit
DEFINE LCD_RWREG PORTC 'LCD read/write port
DEFINE LCD_RWBIT 6 'LCD read/write bit
DEFINE LCD_BITS 8 'LCD bus size 4 or 8
DEFINE LCD_LINES 2 'Number lines on LCD
DEFINE LCD_COMMANDUS 2000 'Command delay time in us
DEFINE LCD_DATAUS 50 'Data delay time in us
TRISD = %00000000 'Set port D as output
TRISC = %00000000 'Set port C as output
TRISB = %11111111 'Set port B as input
low PORTC.6 'Set the R/W bit to low
pause 1000 'wait until the LCD initializes
SCAN:
LCDOUT $FE,1 'clear LCD display
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$0 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "plz train the HM"
IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$0 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "one"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$0 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "two"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "left"
IF PORTB.0=$1 AND PORTB.1=$1 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "jump"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "gil"
IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "three"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "stop"
IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$0 AND
PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "text"
IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$0 AND
PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "point"
IF PORTB.0=$1 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$0 AND
PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "socks"
PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "green"
IF PORTB.0=$1 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$0 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "word too long"
PORTB.5=$1 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "word too short"
IF PORTB.0=$1 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND
PORTB.5=$1 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "word no match"
pause 1000 'delay for 1 second before scanning the next word
GOTO SCAN
END Moderator Edit: Added code tags. Removed block capitals from thread title.
