Hi all! Sorry for my bad English. I decided to build this PSU under the original scheme. I consider that the original scheme is not too bad, if to make small corrections. My corrections in the original scheme: - Replacement of C1 by more capacious 8200mf 63V - Use of two MJE3055T in parallel connection - Use of operational amplifiers OP07CP U1, U2, U3 - Use of BD139 in Q2 * For use of operational amplifier OP07CP (U2) in the original scheme, I have changed in places contacts 5 and 8, look at the picture below. * Also for parallel connection MJE3055T, I have made the small PCB, look at the picture below (7,8,9 are contacts on PCB). As a result when all has been done, nothing works :(. Target voltage regulates from 0 to 0,65 volt, and U2 strongly heats up. Also strongly heats up R1, R2, i think replacing them with more powerful resistors will solve the problem of their heating. My actions: - Before soldering, all parts were checked on serviceability. So all of them were in working order. - I have checked PCB on a possible cracks, but found nothing. - After soldering, i have checked polarity of all parts, all is established correctly. - I have checked all connections with tester (multimetr). All in contact! Help me please! I do not know where can be a problem? Can be some part burned down? Though there are no traces of ignition. Unsolder all parts and to check them, there is no desire.
