hotwaterwizard
Members
  • Posts
    2,022
  • Joined
  • Last visited
Everything posted by hotwaterwizard
  1. Yes it is 2N278 TO-36 PNP GERMANIUM 15A 50V DELCO#5490810 [email protected]
  2. http://auctions.searchmarketing.com/default.aspx?semsearch=hpm+900&submit=Search
  3. JACKPOT!!! Check it out! http://www.techlib.com/electronics/flasher.html http://www.techlib.com/electronics/flipflopflash.htm
  4. Try this. Use DC Voltage while doing this Experiment. Lets Use a 12 volt battery and a 12 volt Relay. Touch you fingers across both the Positive and Negitive of the battery. Nothing, no fealing. Now Connect The Relay Coil Across the Positive and Negitive terminals while touching the wires. Same Thing Until you remove the wires from the battery while holding one wire in each hand. You can feal what happens to the Transistor when no diode is there.
  5. Check out Our other Post on the subject. Drag Lights For Dogs Click Here Here is a simple solution. Just leave out the loop wire! http://www.redcircuits.com/Page72.htm
  6. I just use an Ohm Meter or a Signal Generator. You could Make a Fox-Hound Circuit. Using RF http://www.uoguelph.ca/~antoon/circ/foxhound.html Using AF http://www.pic101.com/foxhound
  7. Check out these Sound Energy Links! http://www.fon.hum.uva.nl/praat/manual/Sound__Get_energy_in_air.html http://fusionanomaly.net/soundwaveenergy.html http://www.rense.com/general/soundwaves.htm http://www.sciencetech.technomuses.ca/english/schoolzone/Info_Sound.cfm http://hyperphysics.phy-astr.gsu.edu/hbase/sound/reflec.html http://www.recordingeq.com/EQ/req1100/wave.htm http://www.physics.usu.edu/classes/4020/soundnotes/sound.htm http://www.newi.ac.uk/buckleyc/sound.htm http://www.cnn.com/TECH/9712/02/sound.wave.energy http://www.macrosonix.com/pdf%20files/Physics%20Today.pdf
  8. How about a water heater thermostat. http://www.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?prod_id=206930&cm_ven=hd_over&cm_cat=Search&cm_ite=26-10-10-water_heater_thermostat-PR-5-206930
  9. SFC2723M Cross Referance Part Numbers TDB1146 SFC2723 LM723 UA723 MC1723 http://matthieu.benoit.free.fr/cross/t.htm http://www1.jaycar.com.au/images_uploaded/LM723.PDF http://perso.club-internet.fr/f5jtz/pjacquet/jtz723.htm [attachment deleted by admin]
  10. Will This help? http://www.itee.uq.edu.au/~comp1300/pracs/_prac4
  11. http://www.philipslogic.com/products/shiftregisters/
  12. Mouser and Digikey both have this IC in stock and by Many Manufactures Here are my search results. http://www.isocomoptocouplers.com/4N29.HTM#package http://www.fairchildsemi.com/ds/4N/4N30.pdf http://www.mouser.com/index.cfm?&handler=data.listcategory&D=78-4N32&terms=78-4N32&Ntt=*784N32*&Dk=1&N=0&crc=true http://www.optocomponents.com/datasheets/db90048.pdf http://www.datasheetarchive.com/181.html http://www.web-tronics.com/4n32.html http://www.vishay.com/docs/83736/83736.pdf http://www.digikey.com/scripts/DkSearch/dksus.dll?KeywordSearch
  13. Is there a ST5512 involved? I have a complete Manual for it 205 pages! Here are some links I came across. http://www.classiccmp.org/transputer/languages.htm http://www.bbk.net.cn/user/revercengineer/downloads/uploads/ST5512ds0300.pdf http://www.classiccmp.org/transputer/documentation/inmos/4944.pdf
  14. J'ai besoin de plus d'information.
  15. Do you want the Module already made or do you want a circuit so you can make one?
  16. Here is a Power Schematic STRG-6153T.pdf
  17. Here is a Phone Project that Uses this IC http://electronickits.com/kit/complete/tele/ak-700.pdf Here is the Datasheet! HM9102.pdf
  18. I found Data for a cross referance part# LND,INC CENTRONICS MULLARD TGM DETECTORS 71412 ZP1311 MX189 N116-1SE / C1312 ZP1311 GM detector http://www.lndinc.com/crosref.htm http://www.lndinc.com/gm/energy/71412.htm
