34 -
Days Won
2
Calendar
Everything posted by sam.moshiri
Whenever you hear the transformerless supply term, you initially imagine the capacitor-based solution, which means a high voltage capacitor in series with the mains line, then a bridge rectifier, a Zener diode, a filtering capacitor, and so on. Such a circuit is not just able to deliver sufficient current for many applications, also, it is not a reliable solution for the industry, although you might see such circuits in some cheap products that are designed to have a low cost. A month ago, I was repairing a washing machine mainboard. In the examination process, I realized that it is equipped with an LNK304 chip that is used in transformerless supplies. So I decided to design a circuit based on this chip to be used in your applications. The circuit contains 220VAC mains input protection, output filtering, and a regulator. To design the schematic and PCB, I used Altium Designer 22 and the SamacSys component libraries (Altium plugin). To get high-quality fabricated PCB boards, I sent the Gerbers to PCBWay and purchased original components using the componentsearchengine.com. To test the current handling and stability of the output voltage, I used the Siglent SDL1020X-E DC Load and examined the power supply output noise using the Siglent SDS2102X Plus oscilloscope. References main: https://www.pcbway.com/blog/technology/220Vac_to_5Vdc_Transformerless_Power_Supply_Using_LNK304_5b2e2d7d.html DB107G schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/DB107-G/Comchip%20Technology LNK304G schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/LNK304GN-TL/Power Integrations 78M05 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/MC78M05CDTG/onsemi Electronic designing CAD software plugins: https://www.samacsys.com/library-loader-help Altium Designer plugin: https://www.samacsys.com/altium-designer-library-instructions Siglent SDL1020X-E DC load: https://siglentna.com/dc-electronic-load/sdl1000x/ Siglent SDS2102X Plus oscilloscope: https://www.siglenteu.com/digital-oscilloscopes/sds2000xp/
- power supply
- lnk304
- (and 7 more)
An ultrasonic range finder is a useful tool in a variety of real-life and robotic applications, such as in obstacle avoidance and distance measurement systems. The ultrasonic range finder measures the distance by emitting a 40KHz pulse of ultrasonic sound that travels through the air until it hits an object, then it measures the delay of the reflected signal and sends proper commands to other units. I used an SRF05 ultrasonic sensor and an ATTiny85 microcontroller. The distance data is displayed on a 128*64 OLED screen, both in centimeters and inches. Also, a horizontal bar graph provides a visual estimation of the distance. The MCU code was developed using the Arduino IDE. To design the schematic and PCB, I used Altium Designer 22 and SamacSys component libraries (Altium plugin). To get high-quality PCB boards, I sent the Gerbers to PCBWay and purchased original components using componentsearchengine.com. To examine the current consumption of the circuit, I used the Siglent SDM3045X multimeter. Isn’t cool?! So let’s get started. Specifications Input Voltage: 6-24VDC Current Consumption: 24mA Detection Range: 2-400cm (see text) Distance Data: Centimeters, Inches, Bar Graph Display: 128*64-Yellow Blue OLED References Ref: https://www.pcbway.com/blog/technology/An_Ultrasonic_Range_Finder_Using_an_SRF05_and_an_ATTiny85_cff7c5cf.html Tool: Altium Designer + Legal License (Free): https://www.altium.com/yt/myvanitar [1]: TS2937CW50 datasheet: https://www.taiwansemi.com/assets/uploads/datasheet/TS2937_E15.pdf [2]: ATTiny85 datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-2586-AVR-8-bit-Microcontroller-ATtiny25-ATtiny45-ATtiny85_Datasheet.pdf [3]: TS2937 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/TS2937CW-5.0%20RP/Taiwan%20Semiconductor [4]: ATTiny85 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/ATTINY85-20SUR/Microchip [5]: Electronic designing CAD software plugins: https://www.samacsys.com/library-loader-help [6]: Altium Designer plugin: https://www.samacsys.com/altium-designer-library-instructions [7]: ATTinyCore Arduino Board Manager: https://github.com/SpenceKonde/ATTinyCore [8]: Arduino New Ping library: https://bitbucket.org/teckel12/arduino-new-ping/wiki/Home [9]: Arduino Tiny4KOLED library: https://www.arduino.cc/reference/en/libraries/tiny4koled [10]: Siglent SDM3045X multimeter: https://siglentna.com/digital-multimeters/sdm3045x-digital-multimeter/
Nowadays, Lithium batteries are used extensively in portable devices, such as cellphones, laptop computers, electronic gadgets, … etc. There is a standard industry-defined procedure (cycle) for charging the lithium-ion/lithium-polymer batteries, otherwise, the lifetime of the batteries is reduced significantly or even they might explode and catch fire. As a basic rule of thumb, a lithium battery should be charged at the rate of 0.5C to 1C. In this article/video, I have introduced a universal double lithium battery charger that the charging current (C rate) can be adjusted simply by changing a resistor value. You just need a 5V power source (such as a mobile charger) and a USB Type-C cable. To design the schematic and PC, I used Altium Designer 22 and the SamacSys component libraries (Altium Plugin). To get high-quality PCB boards, I sent the Gerbers to PCBWay and purchased original components using componentsearchengine.com. To examine the charging current/voltage, I used the Siglent SDM3045X multimeter. Isn’t cool?!, So let’s get started! References Ref: https://www.pcbway.com/blog/technology/Double_Lithium_Ion_Lithium_Polymer_USB_Type_C_Charger_863d1ae1.html [1]: MCP73831 datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/20001984g.pdf [2]: MCP73831 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/MCP73831T-2DCI%2FOT/Microchip [3]: Electronic designing CAD software plugins: https://www.samacsys.com/library-loader-help [4]: Altium Designer plugin: https://www.samacsys.com/altium-designer-library-instructions [5]: Siglent SDM3045X multimeter: https://siglentna.com/digital-multimeters/sdm3045x-digital-multimeter/ Altium Designer + License (Free): https://www.altium.com/yt/myvanitar
- lithium
- lithium ion
(and 3 more)
Tagged with:
The white noise generator circuit is a handy tool that can be used to examine the circuit or a communication line under some random noises to make sure about the stability of the device in real and harsh environments. The current consumption of the device is low, so you can power the circuit using a small 12V-23A battery. if you have access to a 3D printer, you can build a nice enclosure for the circuit. The schematic and PCB have been designed using Altium Designer 22. The output white noise has been tested using the Siglent SDS2102X Plus oscilloscope. References Altium Designer + License (Free): https://www.altium.com/yt/myvanitar
- white noise
- noise generator
- (and 2 more)
The high temperature of the power components is a known phenomenon in electronics. To overcome this challenge, the designers mount heatsinks on the components to dissipate the heat, however, in many commercial and home appliance devices, the embedded heatsink is not adequate and the air must be circulated faster to reduce the heatsink and component temperature, otherwise, the lifetime of the component is reduced significantly. The proposed automatic FAN controller board is simple, compact, and can be embedded inside commercial devices. The LM35 temperature sensor could be fixed on the heatsink using some silicon glue. The user can easily set the temperature threshold using a potentiometer. The board can be supplied using a 5V or a 12V supply, therefore a variety of 5V, 12V, miniature, and PC FANs can be used. I used Altium Designer 21 and SamacSys component libraries (SamacSys Altium plugin) to draw the schematic and PCB. Except for the connectors, all components are SMD and easy to solder. References Source: https://www.pcbway.com/blog/technology/Cooling_FAN_Controller_using_an_LM35_8d3d76cb.html [1]: LM358 datasheet: https://www.st.com/resource/en/datasheet/lm358.pdf [2]: SI2302 datasheet: https://www.vishay.com/docs/63653/si2302dds.pdf [3]: LM358 schematic symbol, pcb footprint, 3D model: https://componentsearchengine.com/part-view/LM358D/STMicroelectronics [4]: Si2302 schematic symbol, pcb footprint, 3D model: https://componentsearchengine.com/part-view/SI2302DDS-T1-GE3/Vishay [5]: Electronic designing CAD software plugins: https://www.samacsys.com/library-loader-help [6]: Altium Designer plugin: https://www.samacsys.com/altium-designer-library-instructions
- 2 replies
- fan
- cooling fan
(and 7 more)
Tagged with:
DC to DC buck converters is a famous topology in the electronic and a widely used circuit in electronic devices. A buck converter steps down the input voltage while it increases the output current. In this article/video, I have discussed a DC to DC buck converter that can be used effectively as a switching power supply. The output voltage and current are adjustable: 1.25V to 30V and 10mA to 6A (continuous). The power supply supports the constant voltage (CV) and constant current (CC) features. Two LEDs demonstrate the CV and CC status. The circuit is compact and both sides of the PCB have been used to mount the components. To design the schematic and PCB, I used Altium Designer 21, also the SamacSys component libraries (Altium plugin) to install the missing schematic symbols/PCB footprints. To get high-quality fabricated PCB boards, I sent the Gerbers to PCBWay. To test the circuit, I used the power analysis feature of the Siglent SDS2102X Plus oscilloscope (or SDS1104X-E), Siglent SDL1020X-E DC Load, and Siglent SDM3045X multimeter. Isn’t cool, so let’s get started! Specifications Input Voltage: 8V to 35VDC Output Voltage: 1.25V to 32VDC Output Current (continuous): 10mA to 6A Output Current (short period): 7A to 8A Output Noise (no load): 6mVrms (9mVp-p) Output Noise (6A load): 7mVrms (85mVp-p) Output Noise (6A load, 16P-average): 50mVp-p Efficiency: up to 96% References Source: https://www.pcbway.com/blog/technology/0_30V__0_7A_Adjustable_Switching_Power_Supply.html [1]: XL4016 datasheet: http://www.xlsemi.com/datasheet/xl4016%20datasheet.pdf [2]: MBR20100 datasheet: https://www.diodes.com/assets/Datasheets/MBR20100C.pdf [3]: TS4264 datasheet: https://www.mouser.com/datasheet/2/395/TS4264_D15-1142598.pdf [4]: MCP6002 datasheet: https://componentsearchengine.com/Datasheets/2/MCP6002T-I_SN.pdf [5]: Altium Designer: https://www.altium.com/yt/myvanitar [6]: SamacSys Altium plugin: https://www.samacsys.com/altium-designer-library-instructions [7]: Supported SamacSys plugins: https://www.samacsys.com/pcb-part-libraries [8]: XL4016 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/XL4016/XLSEMI [9]: MCP6002 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/search?term=mcp6002 [10]: TS4264 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/TS4264CW50%20RPG/Taiwan%20Semiconductor [11]: MBR20100 schematic symbols, PCb footprint, 3D model: https://componentsearchengine.com/part-view/MBR20100CT-G1/Diodes%20Inc. [12]: Siglent SDS2102X Plus oscilloscope: https://siglentna.com/digital-oscilloscopes/sds2000xp/ [13]: Siglent SDS1104X-E oscilloscope: https://siglentna.com/digital-oscilloscopes/sds1000x-e-series-super-phosphor-oscilloscopes/ [14]: Siglent SDL2010X-E DC Load: https://siglentna.com/dc-electronic-load/sdl1000x/ [15]: Siglent SDM3045X Multimeter: https://siglentna.com/digital-multimeters/sdm3045x-digital-multimeter/
- dc to dc buck converter
- adjustable switching power supply
- (and 5 more)
Many electronic beginners are afraid of designing SMD boards and just stick to through-hole and dip components. The reason for this could be using the wrong electronic designing CAD software. This video intends to handle you a complete, although a simple example of a project using both SMD and through-hole components, design rules, tented vias, .. etc. Finally, you can download the Altium schematic and PCB files and play with them. References [1]: Altium Designer Electronic Design CAD software: https://www.altium.com/altium-designer/
DC to DC Boost Converter using UC3843
sam.moshiri posted a topic in Electronic Projects Design/Ideas
DC to DC converters are quite popular among electronic enthusiasts and are widely used within the industry. There are three major types of non-isolated DC to DC converters: buck, boost, and buck-boost. In this article/video, I used there major components such as the famous UC3843 chip, a power Schottky diode, and an N-Channel Mosfet to design a compact DC to DC boost converter. The input voltage could be as low as 9V that makes it suitable for a variety of applications, such as 12V to 18V conversion to power a laptop computer using a single 12V battery. I used Altium Designer 21 and SamacSys component libraries to design the schematic and PCB. The PCBs have been fabricated by the PCBWay in the green solder mask. Also, I examined the noise figure of the circuit using the Siglent SDS2102X Plus/SDS1104X-E oscilloscope and Siglent SDM3045X multimeter. So let’s get started! References Article: https://www.pcbway.com/blog/technology/DC_to_DC_Boost_Converter_using_UC3843.html [1]: UC3843 Datasheet: https://www.ti.com/lit/ds/symlink/uc3843.pdf?HQS=ti-null-null-sf-df-pf-sep-wwe&ts=1626017670986&ref_url=https%253A%252F%252Fcomponentsearchengine.com%252F [2]: MBR20100CT datasheet: https://www.diodes.com/assets/Datasheets/MBR20100C.pdf [3]: IRFZ44 datasheet: https://componentsearchengine.com/Datasheets/2/IRFZ44EPBF.pdf [4]: Altium Designer: Altium Designer - PCB Design Software [5]: SamacSys Altium plugin: Altium Designer PCB Library - FREE - Footprints - Symbols - 3D Models [6]: Supported SamacSys plugins: FREE Schematic Symbols & PCB Footprints - PCB Libraries - 3D [7]: UC3843 schematic symbol, PCB footprint, 3D model: UC3843D8TR footprint, schematic symbol and 3D model by Texas Instruments [8]: IRFZ44 schematic symbol, PCB footprint, 3D model: IRFZ44EPBF footprint, schematic symbol and 3D model by Infineon [9]: MBR20100 schematic symbol, PCB footprint, 3D model: MBR20100CT-E1 footprint, schematic symbol and 3D model by Diodes Inc. [10]: Siglent SDL1020X-E DC load: SDL1000X/X-E Series Programmable DC Electronic Loads | Siglent [11]: Siglent SDS2102X Plus oscilloscope: https://siglentna.com/digital-oscilloscopes/sds2000xp/ [12]: Siglent SDS1104X-E oscilloscope: SDS1000X-E Series Super Phosphor Oscilloscopes | Siglent-
- dc to dc boost converter
- dc to dc converter
- (and 4 more)
Infrared remote controllers are everywhere around us. The majority of home appliances are controlled using infrared remote controls. In this article/video, we learn to build a device that can decode (almost) any IR remote control and use the instructions to switch the relays (loads). So we can use this feature in a variety of applications without buying a new IR remote control and expensive hardware, such as turning ON/OFF the lights, opening/closing the curtains, ... etc. I have used an ATTiny85 microcontroller as the heart of the circuit. The device can record up to three IR codes in the EEPROM memory and switch 3 separate devices. Each relay can handle the currents up to 10A. The load switching mechanism (momentary ON/OFF, toggling, .. etc) can be programmed by the user. I used Altium Designer 21.4.1 and the SamacSys component libraries (SamacSys Altium Plugin) to design the Schematic and PCB. I also used the Siglent SDS2102X Plus/SDS1104X-E to analyze the IR signals. The device works stable and reacts well to the transmitted IR signals. So let’s get started and build this puppy! References Article: https://www.pcbway.com/blog/technology/Infrared_Remote_Control_Decoder___Switcher_Board.html [1]: L7805 datasheet: https://www.st.com/resource/en/datasheet/l78.pdf [2]: TS2937CW-5.0 datasheet: http://www.taiwansemi.com/products/datasheet/TS2937_E15.pdf [3]: VS1838 infrared receiver module datasheet: https://www.elecrow.com/download/Infrared%20receiver%20vs1838b.pdf [4]: FDN360P datasheet: https://www.onsemi.com/pdf/datasheet/fdn360p-d.pdf [5]: ATTiny85-20SUR datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-2586-AVR-8-bit-Microcontroller-ATtiny25-ATtiny45-ATtiny85_Datasheet.pdf [6]: Si2302 datasheet: https://www.vishay.com/docs/63653/si2302dds.pdf [7]: Altium Designer electronic design CAD software: https://www.altium.com/altium-designer [8]: SamacSys Altium plugin: https://www.samacsys.com/altium-designer-library-instructions [9]: ATTiny85 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/ATTINY85-20SUR/Microchip [10]: TS2937-5.0 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/TS2937CW-5.0%20RP/Taiwan%20Semiconductor [11]: L7805 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/L7805CV/STMicroelectronics [12]: SI2302 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/SI2302DDS-T1-GE3/Vishay [13]: FDN360P schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/FDN360P/ON%20Semiconductor [14]: ATTinyCore: https://github.com/SpenceKonde/ATTinyCore [15]: IRRemote library: https://github.com/Arduino-IRremote/Arduino-IRremote [16]: Siglent SDS2102X Plus oscilloscope: https://siglentna.com/products/digital-oscilloscope/sds2000xp-series-digital-phosphor-oscilloscope [17]: Siglent SDS1104X-E oscilloscope: https://siglentna.com/digital-oscilloscopes/sds1000x-e-series-super-phosphor-oscilloscopes
- 1 reply
- circuit
- altium designer
- (and 7 more)
In this video, I explain some theories behind a low pass active filter circuit, then I built a simple active low pass filter using the LM358 opamp. I tested the filter's behavior using the Siglent SDG1025 waveform generator and the Siglent SDS2102X Plus oscilloscope.
- active low pass filter
- active low pass filter circuit
- (and 7 more)
Nowadays USB port is used widely for data transactions between electronic devices and computers. In many scenarios, there is no need to communicate with the USB port directly, therefore electronic designers use USB to UART (RS232-Serial) converter chips, so the USB port is converted to a virtual COM port on the computer. The initial thought of many designers is to use FTDI chips to do the USB to UART conversion. There is nothing wrong with FTDI chips, however, they are expensive. In this article/video, I introduced a cheap USB to UART converter module that uses the MCP2200 chip from Microchip. The converter supports both 3.3V and 5V serial logic levels and uses three LED indicators for power connection, data transmission, and data reception. The module supports the serial CTS and RTS pins, also six GPIOs that can be used for direct controlling of connected devices. The serial data of the module has been examined and decoded using the UART decoding feature of the Siglent SDS2102X Plus oscilloscope. So let’s get started! References Article:https://www.pcbway.com/blog/technology/Cheap_USB_to_UART_Converter_using_Microchip_MCP2200.html [1]: MCP2200 datasheet: https://www.mouser.se/datasheet/2/268/22228A-81933.pdf [2]: RT9166-33GX datashet: https://www.richtek.com/assets/product_file/RT9166=RT9166A/DS9166A-23.pdf [3]: MCP2200 schematic symbol, PCB footprint, and 3D model: https://componentsearchengine.com/part-view/MCP2200-I/SO/Microchip [4]: RT9166-33GX schematic symbol, PCB footprint, and 3D model:https://componentsearchengine.com/part-view/RT9166-33GX/RICHTEK [5]: Electronic designing CAD software plugins: https://www.samacsys.com/library-loader-help [6]: Altium Designer plugin: https://www.samacsys.com/altium-designer-library-instructions [7]: Microchip MCP2200 configuration utility: https://ww1.microchip.com/downloads/en/DeviceDoc/MCP2200 Configuration Utility v1.3.1.zip [8]: Siglent SDS2102X Plus oscilloscope: https://www.siglenteu.com/digital-oscilloscopes/sds2000xp
- rs232
- usb to uart
(and 4 more)
Tagged with:
In this video, I have reviewed the DS-VC288 panel mount voltmeter/Ammeter using the Siglent SDM3045X benchtop multimeter. The VC288 meter did not present acceptable readings, especially in the current measurement. It uses an LM358 Opamp which is not suitable for this purpose and it does not show a linear behavior. The SDM3045X multimeter was used as a reference. I have tested the voltage and current readings separately.
A tip: As I mentioned in the video, in the last revision of the PCB board (which is available for you), the distance between electrolytic capacitors and the power resistors has been increased, however, if you still have concerns about this, you can use 470uF-50V capacitors instead of 1000uf-50V capacitors which are smaller in diameter.
Power supplies are one of the most popular topics in electronics. There are two major types of regulated power supply: linear and switching. Both power supply types introduce some advantages and disadvantages, however, a linear power supply offers better line and load regulation figures and it handles lower noise at the output, specifically when the power supply is adjustable and the output is under load; although its efficiency is lower than a switching power supply. In this article/video, I introduced an adjustable 30V-4A linear power supply that provides constant voltage and constant current adjustment. The output noise of the power supply is low and has measured using the power analysis feature of the Siglent SDS2102X Plus oscilloscope. All component packages are through-hole, so you don't need any special tool for soldering. Let's get started! Specifications Input Voltage (max): 35V [30V, max-tested] Output Voltage (min): 1.28V Output Voltage (max-tested): 27.35V [28.9Vin, no load, 25C] Output Current: 1.1mA to 4A(max continous) Output Noise (no load): 6-7mVpp Output Noise (1A load): 6-7mVpp Output Noise (2A load): 8-10mVpp References Article: https://www.pcbway.com/blog/technology/30V_4A_Adjustable_Power_Supply__CC_CV_.html [1]: LM338 datasheet: https://www.mouser.com/datasheet/2/405/lm338-440432.pdf [2]: IRLZ44 datasheet: https://www.vishay.com/docs/91328/sihlz44.pdf [3]: LM358 datasheet: https://www.mouser.com/datasheet/2/308/lm358-d-299970.pdf [4]: 78L09 datasheet: https://www.jameco.com/Jameco/Products/ProdDS/192225.pdf [5]: LM358 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/LM358N%2FNOPB/Texas%20Instruments [6]: 78L09 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/MC78L09ACPG/ON%20Semiconductor [7]: LM338 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/LM338T%2FNOPB/Texas%20Instruments [8]: IRLZ44 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/IRLZ44NPBF/Infineon [9]: Electronic designing CAD software plugins: https://www.samacsys.com/library-loader-help [10]: Altium Designer plugin: https://www.samacsys.com/altium-designer-library-instructions [11]: Siglent SDS2102x Plus oscilloscope: https://www.siglenteu.com/digital-oscilloscopes/sds2000xp
FM transmitters/receivers are among the top favorite circuits of any electronic enthusiast. In this article/video, I have introduced a complete digital FM receiver design that has equipped with an LCD screen and three push-buttons. It can search for the FM signals from 76MHz to 108MHz manually and automatically (Scan mode). The signal strength is also displayed as a bar graph on the LCD screen. The output sound is amplified by a 3W+3W Class-D stereo amplifier that handles high-quality and strong enough audio power. As a controller, I have used the cheap and popular Arduino-Nano board. So let’s get started! References Article: https://www.pcbway.com/blog/technology/A_Digital_FM_Receiver_with_Arduino.html [1]: TEA5767 Datasheet: https://www.sparkfun.com/datasheets/Wireless/General/TEA5767.pdf [2]: TEA5767 Schematic Symbol, PCB Footprint, and 3D Model: https://componentsearchengine.com/part-view/TEA5767HN%2FV3%2C118/Nexperia [3]: PAM8403 Datasheet: https://www.mouser.com/datasheet/2/115/PAM8403-247318.pdf [4]: PAM8403 Schematic Symbol, PCB Footprint, and 3D Model: https://componentsearchengine.com/part-view/PAM8403DR/LITTELFUSE [5]: TS2937 Datasheet: https://www.mouser.com/datasheet/2/395/TS2937_D13-522475.pdf [6]: TS2937 Schematic Symbol, PCB Footprint, and 3D Model: https://componentsearchengine.com/part-view/TS2937CW-5.0%20RP/Taiwan%20Semiconductor [7]: CAD Plugins: https://www.samacsys.com/library-loader-help
- fm radio with arduino
- arduino fm receiver
(and 3 more)
Tagged with:
In this video, I've talked about the XY mode/feature of a Siglent SDS1104X-E oscilloscope and used it in a combination with a Siglent SDG1025 waveform generator to show how you can build an interesting component tester (V-I curve tracer) to test silicone diodes, Zener Diodes, Schottky diodes, LEDs, Resistors, transistors, capacitors .. etc. Also, you can use it to learn about the behavior of the components and semiconductors. You only need to follow a very simple circuit (schematic) and hock the probes to the correct circuit points. In the video, I have tested these components: 330-ohm resistor, 1N4007 diode, 1N4148 diode, 1N5819 Schottky diode, a white LED and a green LED. the memory depth of the oscilloscope was set on 7M.
- diode test
- xy mode of the oscilloscope
- (and 2 more)
H Bridge PWM DC Motor Driver + PCB
sam.moshiri replied to sam.moshiri's topic in Electronic Projects Design/Ideas
Thanks- 4 replies
- dc motor pwm control
- h bridge circuit
- (and 4 more)
An H-Bridge (Full-Bridge) driver is quite popular in driving loads such as brushed DC motors and it is widely used in robotics and industry. The main advantages of using an H-Bridge driver are: high efficiency, rotation direction change, and braking the motor. In this article/video, I have introduced a complete H-Bridge DC motor driver using four IR3205 power MOSFETs and two IR2104 MOSFET drivers. Theoretically, the above-mentioned MOSFET can handle currents up to 80A, however, in practice we can expect to get currents up to 40A if the MOSFET temperature is kept as low as possible, using a big heatsink or even a fan. References Article: https://www.pcbway.com/blog/technology/Powerful_H_Bridge_DC_Motor_Driver.html [1]: IRF3205 Datasheet: http://www.irf.com/product-info/datasheets/data/irf3205.pdf [2]: IR2104 Datasheet: https://www.infineon.com/dgdl/Infineon-IR2104-DS-v01_00-EN.pdf?fileId=5546d462533600a4015355c7c1c31671 [3]: 1N5819 Datasheet: https://www.diodes.com/assets/Datasheets/ds23001.pdf [4]: IR2104 Schematic Symbol, PCB Footprint, 3D Model: https://componentsearchengine.com/part-view/IR2104PBF/Infineon [5]: IRF3205 Schematic Symbol, PCB Footprint, 3D Model: https://componentsearchengine.com/part-view/IRF3205ZPBF/Infineon [6]: CAD Plugins: https://www.samacsys.com/library-loader-help
- 4 replies
- h bridge circuit
- (and 4 more)
Features High stability and no sensitivity to the ambient light Laser-cut acrylic (plexiglass) enclosure Cost-effective Flow control capability of the hand-sanitizer/alcohol (efficiency) Through-hole components (easy to solder) Single-layer PCB board (easy to fabricate) Single and cheap ATTiny13 microcontroller Low standby current consumption As we all know, the COVID-19 outbreak hit the world and changed our lifestyle. In this condition, alcohol and hand sanitizers are vital, expensive, and in some areas hard to find fluids, so, they must be used properly and efficiently. In the second version of the hand sanitizer dispenser device, I have addressed the previous design problems and introduced a device with no sensitivity to the ambient light and flow control capability of the alcohol/sanitizer. Therefore just enough amount of liquid will be poured on each request. The design uses a cheap ATTiny13 microcontroller. References Source: https://www.pcbway.com/blog/technology/Automatic_Hand_Sanitizer_Dispenser__Version_2___Using_ATTiny13.html [1]: TSOP1738 datasheet: https://www.batronix.com/pdf/tsop17xx.pdf [2]: 2N7000 datasheet: https://www.onsemi.com/pub/Collateral/NDS7002A-D.PDF [3]: ATTiny13 datasheet: https://componentsearchengine.com/Datasheets/1/ATtiny13-20PU.pdf [4]: BD139 datasheet: https://www.st.com/resource/en/datasheet/bd140.pdf [5]: 2N7000 schematic symbol and PCB footprint: https://componentsearchengine.com/part/1011182/model/download [6]: BD139 schematic symbol and PCB footprint: https://componentsearchengine.com/part/1041398/model/download [7]: ATTiny13 schematic symbol and PCB footprint: https://componentsearchengine.com/part/235118299/model/download [8]: CAD Plugins: https://www.samacsys.com/library-loader-help
- 1 reply
- ambient light
- hand sanitizer dispenser
- (and 4 more)
References Article: https://www.pcbway.com/blog/technology/4000W_Standalone_Digital_AC_Dimmer_Using_STM32.html [1]: TLP521 Datasheet: https://www.futurlec.com/Datasheet/LED/TLP521.pdf [2]: BTA26 Datasheet: https://www.mouser.com/datasheet/2/389/cd00002264-1795706.pdf [3]: AN437, ST Application Note: https://www.st.com/resource/en/application_note/cd00004096-rc-snubber-circuit-design-for-triacs-stmicroelectronics.pdf [4]: MOC3021 Datasheet: http://www.farnell.com/datasheets/97984.pdf [5]: AMS1117-3.3 Datasheet: http://www.advanced-monolithic.com/pdf/ds1117.pdf [6]: STM32F030F4 Datasheet: https://www.mouser.com/datasheet/2/389/dm00088500-1797910.pdf [7]: Schematic Symbol and PCB Footprint of TLP521: https://componentsearchengine.com/part/1774908/model/download [8]: Schematic Symbol and PCB Footprint of MOC3021: https://componentsearchengine.com/part/229006098/model/download [9]: Schematic Symbol and PCB Footprint of BTA26-600: https://componentsearchengine.com/part/1587919/model/download [10]: Schematic Symbol and PCB Footprint of AMS1117-3.3: https://componentsearchengine.com/part/656857/model/download [11]: Schematic Symbol and PCB Footprint of STM32F030F4: https://componentsearchengine.com/part/182014793/model/download [12]: Electronic CAD Plugins: https://www.samacsys.com/library-loader-help [13]: 2N7002 Datasheet: https://www.diodes.com/assets/Datasheets/ds11303.pdf [14]: Schematic Symbol and PCB Footprint of 2N7002: https://componentsearchengine.com/part/228320879/model/download
- dimmer
- stm32 circuit
(and 5 more)
Tagged with:
You're welcome. it doesn't have a controller. the intention was to find the easiest and cheapest solution. Please follow the video and provided resources.
- 3 replies
- hand sanitizer
(and 2 more)
Tagged with:
As we all know, the COVID-19 outbreak hit the world and changed our lifestyle. In this condition, Alcohol and hand sanitizers are vital fluids, however, they must be used properly. Touching alcohol containers or hand sanitizers with infected hands can spread the virus to the next person. In this article, we will build an automatic hand sanitizer dispenser that uses IR sensors to detect the presence of a hand and activates a pump to pour the liquid on the hand. The intention was to find the cheapest and easiest solution and design a circuit. Therefore no Microcontroller or Arduino has been used. Two designs have been introduced and you are free to select and build any of them. The first design uses SMD components and the second design is even simpler. It uses DIP components on a small single layer PCB board. References Article: https://www.pcbway.com/blog/technology/DIY_Automatic_Hand_Sanitizer_Dispenser__without_Arduino_or_MCU.html [1]: AMS1117-5.0 Datasheet: http://www.advanced-monolithic.com/pdf/ds1117.pdf [2]: LM555 Datasheet: http://www.ti.com/lit/ds/symlink/lm555.pdf?&ts=1589508422474 [3]: TSOP1738 Datasheet: https://eu.mouser.com/datasheet/2/427/introductionpartnumbers-1766653.pdf [4]: NDS356 Datasheet: https://eu.mouser.com/datasheet/2/308/NDS356AP-D-1813031.pdf [5]: AMS1117-5.0 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=2376678 [6]: LM555 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=380204 [7]: TSOP1738 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=1116997 [8]: NDS356 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=840198 [9]: CAD Plugins: https://www.samacsys.com/library-loader-help [10]: LM393 Datasheet: http://www.ti.com/lit/ds/symlink/lm393-n.pdf?&ts=1589509317025 [11]: BD140 Datasheet: https://www.mouser.com/datasheet/2/149/BD140-888626.pdf [12]: LM393 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=298790 [13]: BD140 Schematic Symbol and PCB Footprint: https://componentsearchengine.com/part.php?partID=166782
- 3 replies
- hand sanitizer
(and 2 more)
Tagged with:
