34 -
Days Won
2
Calendar
Everything posted by sam.moshiri
LM317 is one of the most popular adjustable regulator chips. The output voltage of the regulator can be adjusted from 1.25V to 35V. However, the chip can deliver currents up to 1.5A which is not enough for some power applications. In this article/video, I will discuss two methods of LM317 current boosting, using power PNP and NPN pass transistors. References Article: https://www.pcbway.com/blog/technology/LM317_Current_Boosting_Secrets.html [1]: LM317 Datasheet: http://www.ti.com/lit/ds/slvs044x/slvs044x.pdf [2]: LM317 Library: https://componentsearchengine.com/part.php?partID=299235 [3]: MJ2955 Datashet: https://www.mouser.com/datasheet/2/308/2n3055-d-1190033.pdf [4]: MJ2955 Library: https://componentsearchengine.com/part.php?partID=697997 [5]: 2N3055 Datahseet: https://www.onsemi.com/pub/Collateral/2N3055-D.PDF [6]: 2N3055 Library: https://componentsearchengine.com/part.php?partID=788620 [7]: CAD Plugins: https://www.samacsys.com/library-loader-help
- lm317 power supply
- lm317 current boost circuit
(and 1 more)
Tagged with:
Features: AC – DC Conversion Double output voltages (Positive – Ground – Negative) Adjustable positive and negative rails Just a Single-Output AC transformer Output noise (20MHz-BWL, no load): Around 1.12mVpp Low noise and stable outputs (ideal to power Opamps) Output Voltage: +/-1.25V to +/-25V Maximum output current: 300mA to 500mA Cheap and easy to solder (all component packages are DIP) A double output low noise power supply is an essential tool for any electronics enthusiast. There are many circumstances that a double-output power supply is necessary such as designing pre-amplifiers and powering OPAMPs. In this article, we are going to build a linear power supply that a user can adjust its positive and negative rails independently. Moreover, just an ordinary single-output AC transformer is used at the input. References Source: https://www.pcbway.com/blog/technology/Low_Noise_Adjustable_Linear_AC_DC_Power_Supply.html [1] LM317 Datasheet: http://www.ti.com/lit/ds/slvs044x/slvs044x.pdf [2] LM337 Datasheet: http://www.ti.com/lit/ds/symlink/lm137.pdf [3]: Schematic Symbol and PCB Footprint for LM317: https://componentsearchengine.com/part.php?partID=248007 [4]: Schematic Symbol and PCB Footprint for LM337: https://componentsearchengine.com/part.php?partID=290650 [5]: Altium Plugin: https://www.samacsys.com/altium-designer-library-instructions
- lm317
- low noise supply
- (and 4 more)
The STM8S001J3 is an 8-bit microcontroller that offers 8 Kbytes of Flash program memory, plus an integrated true data EEPROM. It is referred to as a low-density device in the STM8S microcontroller family. This MCU offered in a small SO8N package. In this article, we are going to build a programmable Police LED Flasher device that can be used for vehicles, motorcycles, and bicycles. Schematic + PCB + Code + Full Description References Source: https://www.pcbway.com/blog/technology/Programmable_Police_LED_Flasher_Using_an_STM8.html [1]: https://www.st.com/resource/en/datasheet/l78m.pdf [2]: http://www.ti.com/lit/ds/symlink/lm1117.pdf [3]: https://www.st.com/resource/en/datasheet/stm8s001j3.pdf [4]: http://www.vishay.com/docs/91192/sihfl110.pdf [5]: https://componentsearchengine.com/part.php?partID=1049204 [6]: https://componentsearchengine.com/part.php?partID=4735 [7]: https://componentsearchengine.com/part.php?partID=4735 [8]: https://componentsearchengine.com/part.php?partID=179508 [9]: https://componentsearchengine.com/part.php?partID=235673 [10]: https://www.samacsys.com/altium-designer-library-instructions
- stm8
- led flasher circuit
(and 1 more)
Tagged with:
A tiny DC to DC buck converter board is useful for many applications, especially if it could deliver currents up to 3A (2A continuously without heatsink). In this article, we will learn to build a small, efficient, and cheap buck converter circuit. References Full Article: https://www.pcbway.com/blog/technology/DC_to_DC_Buck_Converter_Adjustable__97__Efficient__3A.html MP2315 Library: https://componentsearchengine.com/part.php?partID=930350 Altium Plugin: https://www.samacsys.com/altium-designer-library-instructions
- dc to dc buck converter
- dc to dc step down converter
- (and 2 more)
YouTube: https://youtu.be/AJvhhS8I3Ps Features: Identify a fake Lithium-Ion/Lithium-Polymer/NiCd/NiMH battery Adjustable constant current load (can also be modified by the user) Capable of measuring the capacity of almost any kind of battery (below 5V) Easy to solder, build, and use, even for beginners (all components are Dip) An LCD user interface Specifications: Board Supply: 7V to 9V(Max) Battery Input: 0-5V(max) – no reverse polarity Constant Current Load: 37mA to 540mA(max) – 16 Steps – can be modified by the user The true measurement of a battery’s capacity is essential for many scenarios. A capacity measurement device can solve the problem of spotting fake batteries as well. Nowadays fake Lithium and NiMH batteries are everywhere which don’t handle their advertised capacities. Sometimes it is difficult to distinguish between a real and a fake battery. This problem exists in the spare batteries market, such as cell phone batteries. Furthermore, in many scenarios, it is essential to determine the capacity of a second-hand battery (for instance a laptop battery). In this article, we will learn to build a battery capacity measurement circuit using the famous Arduino-Nano board. I’ve designed the PCB board for dip components. So even beginners can solder and use the device. References Article source: https://www.pcbway.com/blog/technology/Battery_capacity_measurement_using_Arduino.html [1]: https://www.onsemi.com/pub/Collateral/LM358-D.PDF [2]: https://componentsearchengine.com/part.php?partID=671517 [3]: https://componentsearchengine.com/part.php?partID=617283 [4]: https://componentsearchengine.com/part.php?partID=368895 [5]: https://www.samacsys.com/altium-designer-library-instructions
Differential signal measurement in practice To measure a differential signal, we have two options, one is using a differential probe and second is using a two channels oscilloscope. A differential probe is expensive but handles a better accuracy. Using two/four channels oscilloscope is the cheapest method which handles acceptable results. Just you need to connect oscilloscope’s Channel-1 to one of the differential lines/wires and Channel-2 to another one. Then go to the math function and enable CH1-CH2 which means a difference. Then adjust the oscilloscope to observe the signal. You use the run/stop or a single shot button to freeze the signal on the screen and examine it. I have examined the ADSL2+ signal on the telephone line using the above-mentioned differential measurement method. Reference: http://bit.ly/2Z7sDTt
- differential measurement
- differential probing
- (and 3 more)
Switching power supplies are known for high efficiency. An adjustable voltage/current supply is an interesting tool, which can be used in many applications such as a Lithium-ion/Lead-acid/NiCD-NiMH battery charger or a standalone power supply. In this article, we will learn to build a variable step-down buck converter using the popular LM2576-Adj chip. Features Cheap and easy to build and use Constant current and constant voltage adjustment [CC, CV] capability 1.2V to 25V and 25mA to 3A controlling range Easy to adjust the parameters (optimum use of variable resistors to control the voltage and current) The design follows the EMC rules It is easy to mount a heatsink on the LM2576 It uses a real shunt resistor (not a PCB track) to sense the current
- buck converter
- (and 5 more)
if you change the mosfets of this circuit, it can handle the voltages up to 600V-DC
This is a nice circuit also (built with PCB)
- 6 replies
- dc motor speed control
- dc motor
(and 17 more)
Tagged with:
- dc motor
- dc motor project
- dc motor hack
- dc motor life hacks
- dc motor science project
- speed control
- long technical
- dc motor speed control pwm
- dc motor simple
- 750w 24v dc motor speed control
- speed control unit
- motor
- speed control motor
- how to make
- amazing
- how to
- new technology
- pwm
