I have used the following attached schematic using a 7486 exclusive or (XOR) chip. It is basically a digital frequency doubler. It relies on the propagation delay of the second and third section to provide an output pulse. With Pin 1 High, the output (pin 11) will be High with a negative going pulse. With Pin 1 Low, the output (pin 11) will be Low with a positive going pulse. Pin 2 is the clock input or a hi/lo switched pulse. The output pulse is pretty narrow so you may want to follow it with a 555 timer or one shot chip to get a desired pulse width out of it. You can probably use a cmos chip like a 4070 for the XOR also, I believe just the pinouts are different.
