TES_Delta Posted October 25, 2003 Report Posted October 25, 2003 Does anybody knows what we call "Pipe Line" in a pc and what exactly does? Thanks in advance Quote
MANOTRONIC Posted October 27, 2003 Report Posted October 27, 2003 "A technique used in advanced microprocessors where the microprocessor begins executing a second instruction before the first has been completed. That is, several instructions are in the pipeline simultaneously, each at a different processing stage. The pipeline is divided into segments and each segment can execute its operation concurrently with the other segments. When a segment completes an operation, it passes the result to the next segment in the pipeline and fetches the next operation from the preceding segment. The final results of each instruction emerge at the end of the pipeline in rapid succession. Although formerly a feature only of high-performance and RISC -based microprocessors, pipelining is now common in microprocessors used in personal computers. Intel's Pentium chip, for example, uses pipelining to execute as many as six instructions simultaneously."This definition comes from www.webopedia.com ;) Quote
TES_Delta Posted November 9, 2003 Author Report Posted November 9, 2003 Thanks man.Thanks a lot Quote
