I have built a power supply using a 25.2v transformer and a LM317T variable voltage regulator. I am using the center tap on the transformer so there is another 12.6v available. My question is how would I add the digital panel meter project on this site into the circuit?
pmontone, the output of your power supply would connect also to the input of this project. Then you will have a digital display.
There is a conversation about this project that will also give you pointers. You should use the search to find it or follow the link from the project.
MP
