Sandman101 Posted June 14, 2004 Report Share Posted June 14, 2004 Greetings,I have a design question at hand:I have a group of DIO lines, attached to an FPGA, running +3.3V signal levels. Obviously I would like to drive the signals with buffers, which is simple enough. The problem is the outside world of this device has the probability of pulling the DIO lines up to +28V (this would be an accident, not a common occurance). I've been searching for SMT or BGA solutions to this problem (ie. a buffer with this much protection on the output side) and have found none. If, by chance, anyone knows of any ICs that are capable of such a feat, I would greatly appreciate it. In the event no one knows of any individual ICs that would accomplish this task, a discrete component solution will have to do. If anyone has any recommendations, perhaps even an example schematic, it would be appreciated (using Zeners, resistor networks, etc.)thanks for any help! Quote Link to comment Share on other sites More sharing options...
MP Posted July 5, 2004 Report Share Posted July 5, 2004 Why don't you use an MOV, which are used to protect against voltage spikes and lightning strikes? Another alternative would be to use a resistor and a zener. MP Quote Link to comment Share on other sites More sharing options...
Sandman101 Posted July 13, 2004 Author Report Share Posted July 13, 2004 By resistor and zener you mean:DIO ---/\/\/--------- DIO OUT | ---- / \ | | GNDI choose a zener with zener voltage equal to the DIO voltage level .. but what about the resistor ... isn't the resistor going to cause a voltage drop? what is an ideal value for a 3.3V level ?Thanks for the help! Quote Link to comment Share on other sites More sharing options...
MP Posted July 13, 2004 Report Share Posted July 13, 2004 The MOV might be the best choice since you are only using 3 volts. Yes, you will have a voltage drop across the resistor. You must always have a larger input than the zener voltage to make this workable. Your voltage drop will be the value of Vinput - Vzener. This voltage drop divided by the resistor value will determine the current of your circuit.MP Quote Link to comment Share on other sites More sharing options...
Sandman101 Posted July 15, 2004 Author Report Share Posted July 15, 2004 Would an MOV protect the line if the +28V was applied in a long-term sense, as in, indefinite protection? I'm not looking for spike protection, but a user mistakingly setting the pin to 28V without good monitoring (ie, it's left on long-term).Is an MOV going to cut it? Quote Link to comment Share on other sites More sharing options...
ante Posted July 15, 2004 Report Share Posted July 15, 2004 Sandman,Maybe you should use a Quote Link to comment Share on other sites More sharing options...
ante Posted July 15, 2004 Report Share Posted July 15, 2004 Sandman,Here is an example: http://www.electronics-lab.com/projects/power/034/Ante ::) Quote Link to comment Share on other sites More sharing options...
Sandman101 Posted July 20, 2004 Author Report Share Posted July 20, 2004 Ante,My setup requires the protection to be "resetable" .. as in not a fuse blown but just protection that won't stop the system from running. Also, is this setup applicable to a DIO line? The circuit shown is for a power supply...(my thanks to everyone who has been replying!!) Quote Link to comment Share on other sites More sharing options...
MP Posted July 22, 2004 Report Share Posted July 22, 2004 Sandman,Limiting with zener diodes:MP Quote Link to comment Share on other sites More sharing options...
steven Posted September 1, 2004 Report Share Posted September 1, 2004 :)a poly switch may come in handy Quote Link to comment Share on other sites More sharing options...
