steven Posted October 11, 2004 Author Report Posted October 11, 2004 in thes latest pictures are one of my latest high voltage resister deviders, like the first high voltage resister devider, i carefully solderd 100 times 10 million ohms 1/4 watt resisters in sieries, i cut each resister leg to make it shorter then i counted them all to make sure theres 100 of them, then i rechecked the solder joints between each resister, then i coverd them all except the last resister, in black heatshring tubeing , then with a cigarette lighter i heated the heatshrink tubeing covering the resister chain, till its nice and tight, i used a shorter length of pvc pipe for the body, then i wrapped the , the high voltage resister chain, coverd in heatshrink , around the pvc pipe, i used super glue every few inchers to secure the resister chain in place, and i spaced the turns closer together , so as to make the setup more compact, then i used a few coats of varnish to give it all more insulation, then i made the pvc leg strutts for it, ive allso started a smaller one, but ran out of heatshrink tubeing so i used some left over larger diameter stuff but it dident shrink tight enougth so ill test this smaller one latter to see if i get any resister arcovers inside the resister chain Quote
steven Posted October 11, 2004 Author Report Posted October 11, 2004 the multimetr wires are at the top for this latest high voltage resister devider blue for neg and brown for positive, i dident have any red or black wire left to do it the corect colours Quote
