only_lonely Posted September 23, 2004 Report Share Posted September 23, 2004 i need a 8pins IC holder datasheet for my projecti need it for my CADCAM drawing.i want to create a SOIC to DIL socket for my microcontroller chip atTINY15L(8pins).the image below is 16pins.anyboby can help me?THANKS>>> Quote Link to comment Share on other sites More sharing options...
only_lonely Posted September 24, 2004 Author Report Share Posted September 24, 2004 i want to fabricate a SOIC to DIL 8pins socket for my attiny chip on PCB.but i don't hows the schematic look like.can somebody help me ...raftly draw the diagram for me...the image look like below..but it is 16pins.or somebody know how to use eagle?because i found it in atmel lib.but i don't how to copy it to my blank project folder..i don't how to use eagle.pls help..THANKS!!! Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted September 24, 2004 Report Share Posted September 24, 2004 Quote Link to comment Share on other sites More sharing options...
MP Posted September 24, 2004 Report Share Posted September 24, 2004 It is much better when you can make your own.In eagle, you create a blank schematic, then use EDIT, and ADD to retrieve a library part. Put both parts on the schematic and run the wires from pins on one to the other. Pin 1 to Pin1, Pin 2 to Pin 2, etc.After this, there is an icon at the top of the page to turn it into a board layout. Just move the parts onto the board where you want them in this screen. You can run the autorouter from the menu on the top. It is under TOOLS, and then AUTO.MP Quote Link to comment Share on other sites More sharing options...
MP Posted September 26, 2004 Report Share Posted September 26, 2004 If you still need help with this in eagle, let me know the two library parts you want to combine and I will help you with it.MP Quote Link to comment Share on other sites More sharing options...
only_lonely Posted September 26, 2004 Author Report Share Posted September 26, 2004 the chip holder now i have is a normal 8pins holder...for the ic chip(74xx).i follow MP instruction..first create a schematic..edit>add>atmel>attiny15L>...i don't how to continue...i want my circuit like thisTHANKS for your help!! Quote Link to comment Share on other sites More sharing options...
MP Posted September 26, 2004 Report Share Posted September 26, 2004 I just posted the answer to your other post. It looks like you are duplicating posts.Either IC package will be fine and yes pin 1 to pin 1, 2 to 2, etc.MP Quote Link to comment Share on other sites More sharing options...
steven Posted October 16, 2004 Report Share Posted October 16, 2004 :) thiws is the best i can do maybe you could edit this picture Quote Link to comment Share on other sites More sharing options...
