MfsBillw Posted November 21, 2004 Report Share Posted November 21, 2004 I am hopeful for a schematic to build an intermittant blinking tail-light like I once had about twenty years ago. This small, sealed, very few components circuit/gadget had only three wires which were used to connect to: Ground wire, Tail-light wire and Brake-light wire. (*Standard 12 volt system.) Once each four seconds, it pulsed a (6)Six-VOLT AUTOMOTIVE BULB to make it "Flash". When the brakes were applied, it would Flash rapidly. This attention getter was helpful for safety on my M/C. Quote Link to comment Share on other sites More sharing options...
Guest Yevgenip Posted November 21, 2004 Report Share Posted November 21, 2004 I don't have the circuit, but I'll tell you this:get a blinking circuit. in every blinking circuit, there is a capacitor that controls the blink-rate, connect a different capicitor that will decrease the blink-rate parallel to the capistor and use the brake switch to switch between them.Yevgeni. Quote Link to comment Share on other sites More sharing options...
MfsBillw Posted November 21, 2004 Author Report Share Posted November 21, 2004 Thanks Yevgeni; Good idea; and advice for modifying circuit.Billw USA-Tenn. Quote Link to comment Share on other sites More sharing options...
steven Posted November 25, 2004 Report Share Posted November 25, 2004 :)go to the high voltage stuff section click on scr tester, this simple circuit useses a 12 volts auto indicater flasher unit from a car, this flasher unit is what makes your indicaters blink on and off Quote Link to comment Share on other sites More sharing options...
