Jump to content
Electronics-Lab.com Community
Please comment on my project >< thanks~
There is an input current from a CD or a microphone.
Then if the amplitude of the sound exceeds a certain level, it activates the switch opening circuit to open a switch.
The circuit diagram is here, pls click.
Is there any mistakes/flaws with the circuit?
moreover, is the "Voltage Follower" correctly used? I suppose a voltage follower = two "not gates" in conjunction. is it like that?
Thanks very much. I know this is just so simple as high-school level.
Link to comment
Share on other sites
This is what I get:
Forbidden
You don't have permission to access /zipzipivan/Project.GIF on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.33 Server at www.hostima.net Port 80
Link to comment
I am only guessing here, but it looks like you want to activate a relay with the amplitude of the sound.
Is this correct?
MP
thanks, yes you're right. IF the amplitude of sound exceeds a certain level, it activates an electromagnetic relay.
I have several questions:
1) Is Voltage Follower = two "not gates" used in conjuction?
2) Do I have to amplify the amplitude of sound so that the voltage is large enough?
3) Is there any bugs/logic error in the circuit?
4) Any improvement or more convenient ways?
Thanks~
btw, if I want to make use of the frequency of sound instead of amplitude, how can I make it? thanks~!!!
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
