Jump to content
Electronics-Lab.com Community
LED driver
kkyip
V is the supply voltage.
Vf is the LED forward voltage drop found on the datasheet.
I is the forard current - it must be high enough to give reasonable light output but bellow the maximum value listed on the datasheet.
In this example:
I = 10.4mA
Vf = 1.9V
V = 9V
Now you can check that I've used the correct resistor if you want.
Link to comment
Share on other sites
I dont think thats what hes asking. What hes saying is why use a LED driver chip.
Main reason is to have constant current output to a bunch of LEDs.
Most of it explained here:
http://www.siliconchip.com.au/cms/A_100966/article.html
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
