coolcat14 Posted May 1, 2005 Report Share Posted May 1, 2005 I'm new to electronics, but I want to build a circuit to time out my dome light. Say after 15 min. it turns off. (this is for a dome buggy). I have a toggle switch installed, and so I want the light to turn off after 15 min. has elapsed. I also want, if I turn the toggle switch off, the light to turn off.I have an off delay circuit already laid out from a book, however it requires a push button or momentary switch to activate the circuit however I have a lock in toggle switch. So I was thinking to make my toggle switch turn on a time out circuit which will give my off delay circuit the pulse needed to make it active.any ideas?thanks, chris Quote Link to comment Share on other sites More sharing options...
Shahriar Posted May 10, 2005 Report Share Posted May 10, 2005 Dear coolcat14 There is a project in project section of this site named: "Courtesy Light "it is very similar to what U are looking for, but U should make somechanges...HTH - Shahriar Quote Link to comment Share on other sites More sharing options...
prateeksikka Posted May 15, 2005 Report Share Posted May 15, 2005 HI THERE!USE AN RC CIRCUIT IN SUCH A WAY THAT VOLTAGE ACROSS C RISES EXPONENTIALLY,FEED THE CAP VOLTAGE TO THE BASE OF A TRANSISTOR IN CUT OFF.CHOOSE R AND C SUCH THAT AFTER 15 MINS VOLTAGE ACROSS C REACHES 0.7V,THE TRANSISTOR WILL BE DRIVEN INTO SATURATION AND CAN BE MADE TO SWITCH ON AN LED OR A RELAY IN COLLECTOR CIRCUIT.ISNT IT SIMPLE! 8)PRATEEK Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 15, 2005 Report Share Posted May 15, 2005 Hi Prateek,For a 15 minute time period, the capacitor's value and its leakage current will be huge. Maybe you could use forty-five 20M resistors in series and a 1uF low-leakage poly cap. Or one 20M resistor charging forty-five 1uF poly caps in parallel, driving a Mosfet.It is the same problem with a 555 timer IC, so I would use a CD4541 oscillator-timer or a CD4060 oscillator-divider IC with a reasonable resistor and capacitor value. ;D Quote Link to comment Share on other sites More sharing options...
prateeksikka Posted May 15, 2005 Report Share Posted May 15, 2005 hi audioguru!i know that the limits would be crossed and it will be quite difficult to chose RC combination for the same.but what would be the problem with a 555?what are these CD4541 AND 4060?I havnt heard bout them earlier. :oprateek Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 15, 2005 Report Share Posted May 15, 2005 hi Prateek,The same problem of an extremely high resistor value (900M!) and a low-leakage capacitor, plus more current from the 555's input messing-up the timing. The max recommended value of the timing resistor for a 555 is only 20M. A 20M timing resistor would need a 45uF extremely low-leakage timing capacitor (forty-five paralleled 1uF poly ones!). ;D Go to www.datasheetarchive.com and look at the Cmos oscillator/divider/timers. They make long time durations a piece of cake. Google has many timer projects for them.;D Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted May 15, 2005 Report Share Posted May 15, 2005 Use a ICM7555 or even a TS555 with a 10M resistor and a 100uf tantalum capacitor, this will give about 18 miniutes 20 seconds but when you take into account for the leakage current it will be about 15 miniutes. Quote Link to comment Share on other sites More sharing options...
