Muhammad Abu Bakar Posted May 13, 2005 Report Posted May 13, 2005 IRDetectors are much more costly then a green led .However a simple led (eg green or ret or else) can be used as an IR detector. Will somebody tell about its theory. I have not experimented it yet . Quote
audioguru Posted May 13, 2005 Report Posted May 13, 2005 Hi Abu,Someone talked about this before, but I couldn't find it with a site search. Maybe the discussion was on another site.I tried shining a red Led onto another red Led. When they were touching, the receiving LED produced a voltage output with hardly any current. With a couple of cm spacing, it didn't work.I just finished testing it again with a clear red LED. With it touching a 25W incandescent light bulb, it produced 1.5VDC with a small amount of ripple, but was killed with an 82k load. About 1m from 68W flourescent tubes, it produced 2X mains frequency spikes of 400mV p-p without a load. With it touching my TV IR remote that has a range to the TV of more than 5m, it produced nothing! Maybe the 100pF of my 'scope's cable killed the 40kHz modulation.Nice try. ;D Quote
EdwardM Posted May 13, 2005 Report Posted May 13, 2005 Hi Abuthere was an excellent article published in Elektor magazine in July 2004 entitled light sensor technology (measuring daylight using LED's). It is worth trying to get a copy, if only for the impedance converter circuit which has an input impedance in the teraohm region.Author was K.J.Thiesler and according to the mag the download number is 030435-12 and available from www.elektor-electronics.co.uk/dl/dl.htmEd Quote
