cyw1984 Posted September 27, 2005 Report Share Posted September 27, 2005 About Visual Basic6 and RS232 ASCII communicationIf I want to send the value (ASCII) to 8051 series portVB block input:0.010.020.030.040.050.060.070.080.090.10.110.120.130.140.150.160.170.18.......29.9329.9429.9529.9629.9729.9829.9930.00RS232 transmit :0000000100020003000400050006...2985298629872988298929902991299229932994299529962997299829993000If i want display 0-30 with 0.00 (ACSII).....How can I write the VB software , It need to write 3000 structure???? Quote Link to comment Share on other sites More sharing options...
ECET0purdue Posted September 28, 2005 Report Share Posted September 28, 2005 u can use an array. i have never used them in VB but i have in lots of other programming tools.or use a varable. like thisx=.00do( x=x+.01MSComm1.Output = Chr(x))while(x<3000)%this will display it all... is that what you wanted? if you need the other part in it too do this.t=1x=.00do( x=x+.01 %this will keep adding .01 to x t=t++ % this will keep adding 1 to tPrivate Sub Command(t)_Click() %this will sub t for what # it's atMSComm1.Output = Chr(x) %this will sub x for what ever # it's at.End Sub)while(x<3000) % it keeps doing this till x reaches 3000 or what ever % what ever number you put in here.like i said i never programmed in VB but this is how i would guess to do it... and this ishow i would do it in all other programming i have done..cheers,glen Quote Link to comment Share on other sites More sharing options...
cyw1984 Posted October 17, 2005 Author Report Share Posted October 17, 2005 THX~~~But it ;s don't work~~~someone can help?? Quote Link to comment Share on other sites More sharing options...
EdwardM Posted October 17, 2005 Report Share Posted October 17, 2005 Hi cyw1984first thoughts:I presume you don't want to send all 3000 at once to the 8051 but just a current value?You could do something like...Public Sub Send5Chars(Value as string)'The 5 characters have been previously made into a string which looks like "nnnn"MSComm1.Output = Left(Value,1)MSComm1.Output = Left(Value,2)MSComm1.Output = "."MSComm1.Output = Left(Value,3)MSComm1.Output = Left(Value,4)End Sub...and would be invoked like this:Send5Chars "0123"Does that help?Best of Luck Ed Quote Link to comment Share on other sites More sharing options...
ECET0purdue Posted October 18, 2005 Report Share Posted October 18, 2005 o ya add this .int x; to the top of mine and it should work? and make sure x=.00do( x=x+.01MSComm1.Output = Chr(x))while(x<3000)is between the privent sub click() part and the end sub part.. Quote Link to comment Share on other sites More sharing options...
