Jump to content
Electronics-Lab.com Community
Op.Amp. vs. Diff.Amp.
autir
Hi Autir,
An opamp is a building block with extremely high voltage gain and differential inputs.
A differential amplifier is a circuit using a single opamp or 3 of them, with the inputs properly biased and with negative feedback for a certain defined voltage gain.
Some differential amplifier circuits are already made as an IC and are called Intrumentation Amplifiers. Some even have differential outputs.
;D
Link to comment
Share on other sites
  • 2 weeks later...
Well, a single transistor amplifer needs a lot of negative feedback to make it linear, then it doesn't have any voltage gain. An opamp amplifier has both.
A two and three transistors amplifier is much better but approaches becoming an opamp.
http://www.dself.dsl.pipex.com/ampins/discrete/cfp.htm
http://www.dself.dsl.pipex.com/ampins/discrete/singleq.htm
http://www.dself.dsl.pipex.com/ampins/discrete/twoq.htm
http://www.dself.dsl.pipex.com/ampins/discrete/discrop.htm
Link to comment
  • 2 weeks later...
It's the design that makes it linear of analogue, you can use an op-amp as a digital comparator, and you can just as easily use a 4011 as an analogue amplifier. IC's are called analogue or digital because it's how they are normally used. You can also use a BJT as a digital switch or an analogue amplifier.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
