walid Posted October 12, 2005 Report Share Posted October 12, 2005 In the figure below you can see a transformerless power supply circuit, the component values are as follows:R1 = 220K Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 13, 2005 Report Share Posted October 13, 2005 I wouldn't call it a power supply because its ouput current is nearly nothing.It only puts about 1.6mA into the zener and output capacitor only half the time because it is half-wave. Therefore the 1.6mA will go into the zener and the output current and voltage will be very low.R2 limits the charging current into C2 to 0.6A if it was connected to the mains at the moment it was at its peak of +311V. Quote Link to comment Share on other sites More sharing options...
walid Posted October 13, 2005 Author Report Share Posted October 13, 2005 Hi AudioguruFirst of all I thank you for your kind answer. you must complete the road with me to make me understand as you hope, so(1) The 1.6mA, I think you depend on my calculations to get this number, that is 1.6mA approx = 220Vrms/130.5Kohm, is this true?(2) If (1) is true, R2 must connected to GND, where is it? (3) I agree with you that it is a half wave, D2 passing the +ve half to zener, and D1 passing the -ve half to GND, the question is why D1, I think that D2 is sufficient to do the job!(4) If I want this circuit to provide me a 12 VDC 50mA, I do the following: ->for 12VDC I use a 12V zener ->for 50 mA I reduce the Rtot to 220/50m = 4.4K ohm\ -> calculate C2, R1, R2 as follows: C2 is the same 10nF 400V Ceramic or Polyester Capacitor R2 also the same = 470R Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 14, 2005 Report Share Posted October 14, 2005 (1) The 1.6mA, I think you depend on my calculations to get this number, that is 1.6mA approx = 220Vrms/130.5Kohm, is this true?220V - 12V / 130.5k = 1.6mA, but since it is half-wave it will be about half.(2) If (1) is true, R2 must connected to GND, where is it?The zener is connected to gnd. Quote Link to comment Share on other sites More sharing options...
walid Posted October 17, 2005 Author Report Share Posted October 17, 2005 Hi audioguruThank you very much for your very good answer, especially that part about D1 which helps in discharging the cap C2.Now, I use Electronic Workbench EDA software to simulate the circuit shown below as Fig.PU1. I noticed that the readings are dependant on R_load value. At low values of R_load zener OFF and I_z = 0 A.I record some of these values as follow:R_load I_c2 I_R1 Iz I_load V_load10K 106.4 1.466 46.30 1.2 12.055K 105.8 1.457 44.24 2.4 12.051K 105.9 1.456 34.33 12.02 12.020.2K 104.4 1.452 0 46.25 9.250.01K 107.2 1.467 0 47.5 0.475Can you please explain why this dependence?thank you very much.walid. Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted October 17, 2005 Report Share Posted October 17, 2005 Notice how the voltage doesn't change much until the load is under 1k? That's because (as audioguru said) it's not a proper power supply. You'll find this is the same for any supply, try putting a 6 ohm load on a LM7812 power supply and see what happens to the load voltage. The maximum current you circuit can supply is about 10mA which is fine for small CMOS circuits but not much use for anything else, also it isn't isolated from the mains so the circuit running from it should be enclosed in an insulated box. Quote Link to comment Share on other sites More sharing options...
walid Posted October 17, 2005 Author Report Share Posted October 17, 2005 Thank you Alun But I need more explinations if you or other person can.thank you all. Quote Link to comment Share on other sites More sharing options...
walid Posted February 27, 2007 Author Report Share Posted February 27, 2007 hiplease look at the following circuit, it is a transformerless power supply:this is a 12 volt and can supply a max current = 15 mAI calc this current as:Xc = 1/2 pi f C = 14.47 K ohmI = (220 -12 - 1.4)/Xc = 15 mAthe 1.4 volt is the drop voltage on two diodesNow, please tell me What are the disadvantages of this circuit, andwhy the zener diode is Often burnedwhat if i connect 100 to 300 ohm resistor in series with that diode.the last question: at the ollowing circuit, why using R3 =220 ohmits value did not affect the the current at allguru said before that: "The circuit needs this resistor to limit the current in C1 if the circuit was connected to the mains at the moment it is at its peak of 311V"I did not fully understand the intent, especially, I know that the freq of electricity = 50 that the voltage reaches 311 fifty times per second, how can this be?thank you very much. Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 27, 2007 Report Share Posted February 27, 2007 Hi Walid,Your mains is a sine-wave that goes from a peak voltage of 311V then through 0V to 311V with the other polarity and continues to alternate. If the circuit is connected to the mains at a moment when the voltage is at a 311V peak and there is not a resistor to limit the capacitor's charging current then the current will be huge and might cause damage.I don't see anything in the circuit to cause the 1W zener diode to burn. Its max dissipation is 12V x 15mA= only 180mW. Quote Link to comment Share on other sites More sharing options...
walid Posted February 27, 2007 Author Report Share Posted February 27, 2007 Hi guru(1) the word "at the moment" is the problemif we agree that the voltage reaches 311 volt 100 times per a secondthat is every 1/100 sec the voltage value is 311vin the human sense it is every time, every any bit of time..........(2) in this circuit there is no resistor to limit the capacitor's charging current, why there is no problem?(3)Also related to the above circuit; if i increase C1 to 900nF to get about 60mA, when there is no load, zener eats all this currentif it is, for discussion, 1/2 watt it will be burned, so if i don't want to use a 2watt zener, and i want to use a 300 ohm resistor in series with the 1/2 watt zener, would this protect the zener?How much this resistor decrease the current?thank you very much Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 27, 2007 Report Share Posted February 27, 2007 It is a dangerous and bad circuit. Of course there is a problem if nothing limits the capacitor's charging current. If the capacitor is not rated for high currents then it will fail.The fuse limits the current like a resistor. A fuse is a resistor.If a 300 ohm resistor is in series with the zener diode then it reduces the current only a tiny amount, because it is also in series with the much higher reactance of the current-limiting capacitor. Quote Link to comment Share on other sites More sharing options...
walid Posted February 27, 2007 Author Report Share Posted February 27, 2007 hi guruto the following circuit, (1)if i changed it to be a half wave rectifier, is the current still 15 mA as with full wave(2) what the difference of putting a 300 ohm resistor in place of the red line or blue line in the followin circuit.thanks Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 27, 2007 Report Share Posted February 27, 2007 With a half-wave rectifier the current will be about half and the ripple voltage will be doubled.If a resistor is added in series with the zener diode then it is also in series with the much higher reactance of the current-limiting capacitor, so the zener diode current or the load current will be reduced only a tiny amount. Quote Link to comment Share on other sites More sharing options...
walid Posted February 27, 2007 Author Report Share Posted February 27, 2007 ok thanks guruin the following schematic:Why ZD1 and ZD2?thanks Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 27, 2007 Report Share Posted February 27, 2007 The last dangerous circuit has too many resistirs and too many zener diodes. Quote Link to comment Share on other sites More sharing options...
walid Posted February 27, 2007 Author Report Share Posted February 27, 2007 I asked why ZD1 and ZD2 in this schematic Quote Link to comment Share on other sites More sharing options...
walid Posted February 28, 2007 Author Report Share Posted February 28, 2007 Hi I answer myselflook at the followig figure:At the +ve half of the main AC voltage (311 V peak) the upper zener acts as a diode and the lower zD2 acts as a zener regulating the voltage to 16.7vAt the -ve half of the main AC voltage (-311 V peak) the lower zener acts as a diode and the upper zD1 acts as a zener regulating the voltage to -16.7vIn my software there is no 16V zener, there is a 15 v zener so I use it to simulate this part of the circuitTHANKS TO MY TEATCHER AUDIOGURU WHO LEARN ME 99.9999% of what I know in ELECTRONICS Quote Link to comment Share on other sites More sharing options...
