Staigen Posted October 28, 2005 Report Share Posted October 28, 2005 HiI need the datasheet for SN76008 IC. Its a sound power output IC in a pentawatt enclosure, probably made by Texas Instruments.TIA Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted October 29, 2005 Report Share Posted October 29, 2005 Not Easy to find info for.Cross Ref NTE746Datasheet. http://www.nteinc.com/specs/700to799/pdf/nte746.pdf Quote Link to comment Share on other sites More sharing options...
Staigen Posted October 29, 2005 Author Report Share Posted October 29, 2005 Hi there Hotwaterwizard, i forgot your name :)Thank you very much for your effort, the NTE746 was wrong, but the pic was right, the lowest one ;DBut, what is the max VCC for this IC? :(Can i use a 24 Volt tranny with a bridge and a smoothing cap of say 4700 uF or so, or must it have a stabilised 24 Volt VCC? The TV:s i have seen it in have a stabilized 24 Volt VCC(some Luxor TV:s)! I have a bunch of this IC, and want to build an amp for my computer ;D. Maybee it is the same as TDA2030 ????//Staigen Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted October 29, 2005 Report Share Posted October 29, 2005 I'm sorry I don't know, but even if it has a similar spec and pin out to the TDA2030 I wouldn't assume the voltage is the same, the NE555 is similar to the TS555 but the later is rated to 18V while the former is only 16V. Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted November 10, 2005 Report Share Posted November 10, 2005 I had a hard time finding anything on that IC.SN76008N IC SN76008N AMP22V10WRL=4 ohmsFLATPACK5 PIN Quote Link to comment Share on other sites More sharing options...
