Shahriar Posted November 4, 2005 Report Share Posted November 4, 2005 HiI have a SMPS that its output varies from 4V up to 32V. As you know at the output of most SMPS there must be a Load to Dissipate some power. For my SMPS, it should be at least 2-3W Because this SMPS is to be used as a Laboratory Supply, I have to put a load at the output. I can not use a single resistor. i.e.Vi = 4V & R=8ohm ---> P=V^2 / R = 2WBut if Vi = 32V then P= V^2 / R = 128W So I have to use a constant power consumption circuit. I designed one but it dissipate 8W at Vi=18V and dissipate 2-3W at Vi =32V and dissipate 3W when Vi=4V.I have not build it yet. These writing are from my calculates.This Non-Linearity is because P is proportional to Vi^2.Does anybody have a good Idea?The schematic is attachedMy numbers are not very SharpThanXShahriarConstantPower.pdf Quote Link to comment Share on other sites More sharing options...
audioguru Posted November 4, 2005 Report Share Posted November 4, 2005 Hi Shahriar,I don't like to see your zener diode starved of current when the supply voltage is only 4V, and cooking when the supply voltage is 32V, so I tried it with an LM317 regulator adjusted to 1.25V. I used a resistor on its output to hold its output voltage down. Then I added a common emitter transistor to reduce the load voltage when the supply voltage increased.I didn't have the correct resistor ratios so it didn't work.I'm sorry I don't have enough time now to sketch it nor re-calculate it but I hope you know what I mean. Try it, I think it will give a constant power load. ;D Quote Link to comment Share on other sites More sharing options...
ante Posted November 4, 2005 Report Share Posted November 4, 2005 A MOSFET glued to an NTC (and o few other parts) will draw a constant wattage if the room temperature is reasonably constant. 8) Quote Link to comment Share on other sites More sharing options...
