Naveed Ali Posted November 26, 2005 Report Posted November 26, 2005 Please post a circuit of antenna less FM xmitter if you have designed such on [email protected]. Looking forward for positive reply.Antenna less means that it is not totally without antenna but antenna may be very small to be noticed perhaps a 1cm or so but it must have a long range and power output.OK...Modifications...FM range = 88-108 MhzPower output = <2WRange = About 500 meters Quote
Guest Alun Posted November 26, 2005 Report Posted November 26, 2005 An Electrically small antenna will work though the resistance will be lower and it will behave like a capacitor.Just use a normal small FM transmitter and add an inductor in series with the antenna.Check out these links for more info:http://www-personal.engin.umich.edu/~lschulwi/Report16.PDFhttp://www.hard-core-dx.com/nordicdx/antenna/wire/shortdipole.htmlhttp://www.ee.surrey.ac.uk/Personal/D.Jefferies/radimp.htmlhttp://www.borg.com/~warrend/guru.html Quote
audioguru Posted November 26, 2005 Report Posted November 26, 2005 Hi Alun,You found some excellent articles about antennas. ;DI don't think it is possible to use a tiny antenna then transmit a high power from it on the FM band. Unless you have gobs of power to waste. Quote
Guest Decade Posted November 26, 2005 Report Posted November 26, 2005 Hi audioguru!You can run kilowatts into a tiny wire but I would worry more about a tiny coax with high losses ;D Quote
Guest Alun Posted November 26, 2005 Report Posted November 26, 2005 I don't think it is possible to use a tiny antenna then transmit a high power from it on the FM band. Unless you have gobs of power to waste.He didn't mention the power level I just assumed <10mW for a legal transmitter.Come to think of there was no mention of the frequency either, he just said FM, you could build a reasonably efficient FM voice transmitter working at the bluetooth frequency of 2.45GHz. Quote
audioguru Posted November 26, 2005 Report Posted November 26, 2005 He said he wants long range with power.The antenna on my cell phone is only about 2cm externally, with a lot more inside, and it is rated to transmit 1W. Quote
