Jump to content
Electronics-Lab.com Community
Help with MJ4502 Transistor
Hello
    I have been reading data sheets and could use some help. I wan to build the power supply on the LM350 data sheet. The problem is in one of the power transisters MJ4502, I don't have one and I would rather use something I have instead. What I have is heaver the the MJ4592. I was thinking of useing a 2N5416, the voltate and current rateings or higher but the hfe is not the same. The MJ4502 hfe is 25 - 100, the 2N5416 hfe is 30 - 120. So I guess my question is will that still work?
Link to comment
Share on other sites
Hi Ante
    I would use a MJ4502 if I could find one. I only going to build a 2 or 3 amp power supply. I'll Keep looking. Two 2n2955 will work, have to see if I can find them.
                                                  Thanks Ante
                                                        gogo
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
