Jump to content
Electronics-Lab.com Community
Posted
Hi u
from what I understand, a magnetic sensor actually senses current, therefore if your closed loop circuit is driven by a voltage then it should be possible to detect that current using a combination of X, Y and Z coils to determine an exact position,  it depends also on how far away you expect to detect the wire, is it a few cm? or 30-40m?
Hope that helps
Ed
You could also try a Google search on magnetic sensors
Posted
Hi u,
A book: “Engineer's Mini-Notebook Magnet and Magnet Sensor Projects” can be found here: http://www.electronics-lab.com/forum/index.php?topic=5379.84
I hope you will find an answer in this book!  ;D
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
